????....i have a couple question about swaping my 95 civic couple with b16a2
Hey everybody, i am swaping my 95 ex coupe with a b16a2.
my first question is will my obd1 stock motor harness plug and play with the with my b16 if i put my obd1 fuel injectors?
other question is will i have to get a b16 obd1 dizzy or can i use my obd2 dizzy?
my last question is will my motor mount post bracket from my stock single cam z6 bolt on to the b16 block
i will thank you alot if you can help me with these simple questions.
thanks
thanks
Re: ????....i have a couple question about swaping my 95 civic couple with b16a2
If your motor is obd1 you can use the obd1 fuel injectors and obd1 dizzy it will plug up... Check your harness, obd1 dizzy is one plug, obd2 is two and the mounting holes are different from 1-2 as well as d-b series. Motor mount should work.
Panda Eg6
05-14-2008 10:05 PM
amazinspiderman
02-13-2006 11:49 AM
