starting trouble - ton of sparks when plug in wire from starter to battery
hey i have 1992 civic hatchback and i was going to move the battery to trunk but when i unplugged the wires coming off the battery.
1. ground
2.cable coming from the fuses
3.starter
when i go to plug in the wire from the starter to the battery there is tons of sparks and then i turn the key there is nothing
can some please help me out
1. ground
3.starter
Re: starting trouble
probably blew a fuse or your main relay. or your dizzy blew up. When you say theres nothing when you tun the key, im assuming you turn the key and it doesn't crank or anything right?
when i turn the key nothing happens no lights ,if i unplug the wire coming from the starter to the battery all the lights will work and the radio will work.
AJWatUC
07-12-2007 05:56 PM
