jdm b18c gsr swap/wiring
got the swap from HMO its in the car just gotta do some wiring, it didnt come with the vtec pressure switch (green plug beside vtec solenoid) was it supposed to ? or can i use the one from my d16y8 or call hmo? also how do i wire up IABS ? someone told me get a 2 pin plug & run one wire to ground & one wire to ecu, where does it go on the ecu?
Re: jdm b18c gsr swap/wiring
yea u will be able to use the y8 wiring but have to extend it and the iab is a17
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A4-VTS VTEC solenoid
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22- *per Sander* Ignitor
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
D6-VTM VTEC pressure switch
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A5-INJ3 INJ3
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A14-empty
A18-empty
A19-**
A21-ICM ICM
A23-PG1 ground
A24-PG2 ground
A26-LG1 gound
B1-IGP2 to pin A25
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D3-KS Knock Sensor
D5-empty
D8-empty
D9-ALT F alternator
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
im in the process of doing the swap with a b18c from HMO right now to, only its going into my 93 cx. If your car was not factory wired for vtec then you will have to run wires for it. Not sure about your chassis. someone else can answer that
my car is a 97 civic ex . it had the vtec d16y8 so i guess i dont have to wire any vtec. anybody got a writeup on wiring up the IABS
iliv2xlr8
03-04-2009 06:16 PM
93(Civic)EG6
08-04-2007 06:10 PM
ilovemyb16a
05-18-2006 12:58 PM
