LS ina EK hatch
LS ina EK hatch
ok its prolly been threded before but i cant seem to find the info i need..
my buddy totaled his obd-2 LS, from the rear and i came up on the entire swap from
the engine bay..
..engine tranny, but not the LS mounts he sold those to another friend.
..harness, ECU
..LS shift linkage
.. and Axles but ther kinda beat up ima replace them..
But the question i ask is what exatly do i need to get this OBD-2 LS into my 96 EK hatch (cx)?
can i use tha LS harness..?
what kind of mounts do i need?
i heard i need a 99-00 si b16 rear bracket..but ive been getting alot of conflicting answers.
Linkage?? can i use tha LS linkage..
wiring mods???? ETC... PLZ help a brotha out
the engine bay..
..harness, ECU
..LS shift linkage
Re: LS ina EK hatch
no youll need a civic harness, integra harness dont work because they are a 2 peice
either a hasport,avid or some other swap mounts, or civic si,
YES you need a si rear bracket. no others will work,.
yep you need a b series linkage, del sol will not work.
depending on if its ob2a or b,, but your harness should be pretty much plug and play, you may need a jumper harness for the ecu, and to extend some things.
Re: LS ina EK hatch
what kind of B series linkage?? off of what??
and like i seen some mount kits off hasport and inoative and they come with a
"rear trans braket" can i use this insted of the 99 si rear bracket??
or is this some completly diff>>??
jumper harness??? but my cars obd-2 and so is the ECU and engine??
Re: LS ina EK hatch
u need rear si t bracket and engine post mount bracket that bolts to block by timing belt u can use your stock ek mounts use your stock harness everything from the acura u can use linkage also
Re: LS ina EK hatch
the engine bay..
..harness, ECU
..LS shift linkage
the engine bay..
..harness, ECU
..LS shift linkage
Re: LS ina EK hatch
WTF is a "idler mount" ?!? and the trim model of my wiring harness?!?
... im hella confused. i always get conflicting info on this SUB..
ok i get the 99si b16 rear T-braket.. but Avid mounts has this kit with a
"rear trans braket".......heres the link
http://cgi.ebay.com/ebaymotors/Avid-...Q5fAccessories
Can i use this insted of the 99si rear T-braket?? i asked the seller on ebay and he dnt reply..
Also... so i can use the 97 acura LS shift linkage??
a buddy told me that i culdnt but iyd rather get other opinions.
Re: LS ina EK hatch
You can use everything from the integra except the wire harness.
(Longblock)
(Tranny)
(Headers/downpipe)
(Intake manifold)
(Shift linkage)
(Ecu) might need a jumper harness
(Axles)
Goodluck on your swap...
sykotik sol
04-22-2003 05:06 PM
