gears starting to grind
over the past couple weeks my transmission has started to grind when I shift gears. it has progressively gotten worse or the past few days. all gears will grind if I dont shift at a low RPM. I have a b18c-LSD tranny with ACT clutch and light flywheel. clutch is 3-4 years old. what is most likely causing this problem? clutch, transmission, low transmission fluid, or other? Thanks for the help
Re: gears starting to grind
or some people like 'syncromesh' from gm.. i use MTF, but ive heard good things about syncromesh, and it fixed the 3rd gear pop-out in a friend of mines 06' si.. since the dealer over filled the tranny from the factory.
ncskate
05-21-2006 08:38 PM
HavokB18
07-26-2003 05:32 PM
