y8 distributor on z6
I have a 98 Civic EX that I'm trying to put a d16z6 motor into. How do I make the y8 distributor work on the z6? I used the y8 intake and sensors so everything else is already OBD2.
Re: y8 distributor on z6
u change out the pan, oil pump and pick up it will work. yes the y8 dizzy works only the top hole lines up and u make have to ream it out some to fit. it does work thats currently how im running mine.
Yup, I already put a new y8 oil pump on it to mount the crank sensor so everything else is good. The motors already in the car and everything except the distributor is sorted.
No problems with the distributor moving with only one bolt holding it?
Seagull Management
You really don't need a Y8 oil pump. You can simply perform the CKF trick shown here ---> http://technet.ff-squad.com/ckftrick.htm
you are going to need the y8 oil pump if u use the y8 ecu...
or switch the whole engine harness to obd1(z6) and ecu jumper
i recently did this
i recently did this
twizted-myatt
05-31-2011 02:34 PM
MinorObsession
02-04-2009 02:17 PM
dohdoh420
23
10-20-2005 05:56 PM
