EG Build *Help*
Old 08-17-2009, 07:40 PM
BLeSR's Avatar
Default EG Build *Help*
how can i tell wat engine i have and if its vtec powered or not? the previous owner said it was.
WORK IS STILL IN PROGRESS
Old 08-17-2009, 07:45 PM
ej1love's Avatar
Default Re: EG Build *Help*
do u feel vtec?
look at the front of the block under the radiator hoses for the engine code, but by the looks of it i dont see a vtec silenoid behind the valve cover...
thecruzs2007@yahoo.com's Avatar
its a d16z6....you can see the green plug for the Vtec siloniod next to the dizzy and also under the valve cover vacum hose...
Old 08-17-2009, 07:46 PM
ej1love's Avatar
its an si?
Old 08-17-2009, 07:49 PM
forcefedferio's Avatar
Originally Posted by ej1love
its an si?
nah it's not an Si, no sunroof.
But it is a z6, i see the VTEC solenoid peakin out from under the breather tube going to the intake from the valve cover.
Old 08-17-2009, 07:50 PM
ej1love's Avatar
ah, now i see it. guess he's got a swap...
BLeSR's Avatar
im not sure if its an si or not but im pretty sure its not. i just took the car cuz it was a gift..
so its a d16z6 not a d16y8?
Old 08-17-2009, 07:51 PM
^^^ yup..
no sun roof=not an si...
does it have a tach?
and for some reason it appears to have a 96-00 d16y7 exhaust manifold on it.
ej1love's Avatar
look at the vin on ur dash for the trim level, eh3 is si; which it isnt...
BLeSR's Avatar
yea its swapped. so its vtec powered rite?
Old 08-17-2009, 07:52 PM
ej1love's Avatar
yea thats y i didnt think it was a z6...
Old 08-17-2009, 07:53 PM
its a d16z6...y8s have the dipstick by the cam gear and z6 have it through the exhaust maifold
Old 08-17-2009, 07:54 PM
BLeSR's Avatar
thanks..are d16z6 any good?
Old 08-17-2009, 07:55 PM
BLeSR's Avatar
is that bad??
Old 08-17-2009, 07:56 PM
the d16y8 is slightly stronger..very slightly..by like 1 or 2 horsepower...but id preffer a d16z6...they are less likely to spin a bearin..so i heard
welpppp, it all depends on what you want to use it for.
Daily driver=
Turbo=
Supercharged=
All Motor=
Old 08-17-2009, 07:57 PM
is that bad??
no, but just be cautious if you buy a different exhaust you may need to do a little custom work depending on how they installed the header.
yes, the y8/y7 motors have inherently weak oil pumps.
Old 08-17-2009, 07:59 PM
^ well said forcefedferio.
BLeSR's Avatar
good to noe.. he had a k20 in it before but it was recently stolen after a year the owner recoverd it just like that..they also stole the emblems..
btw when does the vtec kick in?
in the z6 5500
5500rpm that is
Old 08-17-2009, 08:02 PM
5500rpm that is
yes sir, and your best bet for hearing it (chances are you won't "feel" it) are to do a 3rd gear pull and leave your intake the way it is, with no filter or anything on it. I'm not kidding, that's when it should be the loudest, just don't keep it like that.
Old 08-17-2009, 08:03 PM
ej1love's Avatar
for what it is , its one of the best d's u can have... so is the hatch a cx?
Old 08-17-2009, 08:05 PM
BLeSR's Avatar
yes its a cx.thanks for all the help. hopefully i get to do another swap
Quick Reply: EG Build *Help*
