ek9 ctr mirrors new evolution or something HELP.
put me on blast but this is about ctr mirrors.
my old ones didn't work so i bought another set.
these ones are different and i spent several months looking and giving up... and i didn't want to post to be put on blast but i am.
my switch is TWO row 8 wires.
[1][2][3][4][5][6]
[7][8][****][9]10]
1= blue/ yellow stripe
2=green/ white stripe
3=yellow/ black stripe
4= n/a
5= blue/ black stripe
6=blue/ white stripe
7=black (most likely the ground..)
8=yellow/ red stripe
9=black/yellow stripe
10=n/a
relay is...
[1][2][3][4][5]
1=green/ red stripe
2=black
3=blue/ yellow stripe
4=white/ blue stripe
5=green/yellow
colors do not match across diagrams... and they don't match up on the relay and switch.
TRUST ME... i've searched and searched and there isn't any diagram that still up or up that includes... and i know there are several heads still looking for the right diagram while others are putting kids on blast..
"SEARCH".
we did. we really did.
if you're not a punk and actually willing to help.... please. if you have the diagram... pls up it. and let's really archive this so there is some water to telling people to use the search...
[1][2][3][4][5][6]
[7][8][****][9]10]
4= n/a
10=n/a
relay is...
[1][2][3][4][5]
1=green/ red stripe
2=black
5=green/yellow
"SEARCH".
Re: ek9 ctr mirrors new evolution or something HELP.
BUMP. i know it's not new evolution. l just need a lil help from anyone that's insightful.
hold on what exactly is your question? You have a switch for power folding ctr mirrors that none of the wire colors match up with your harness? Am i right? you should post the diagrams that you have
what i want to do is make use of the USDM wires that i have from my ex power windows... and add whatever lines i need to for the rest.
im confused what is the the power and ground... well the black is the ground.
but sometimes the power is white/blue
sometimes it's yellow/red
and somestimes it's black/yellow.
my switch has all of these on the switch... and im really confused what goes to what.
alrite i see why your confused that is a big mess but i have a diagram of the usdm connector that may help while i try to sort this out
hm... ok. that helps a lil! thanx i guess.........
but! what's the difference between IGNITION INPUT and COMMON?
do you have one for the JDM mirrors by any chance???
i understand those are for defogger...
i need to know how to hook up the folding part to the relay... but yea, that does help alot though. thanx.
sorry i got distracted but common is the wire that is used on every movement its basically the power wire and then each movement also has its own wire. i dont know if that made sense. I dont have a diagram for the jdm mirrors and ive never wired them before and i have no idea how the relay is wired. I think the easiest diagram that you have to understannd is the bottom one that doesnt have any color coding. Combine that with the one i posted and it makes a little more sense. If by tomorrow no one has figured it out i will try to help but right now im going to bed its 1 am here and im beat plus im sick.
I've been working on this for a hot minute wiring mine up at my desk. I used this to get my 12V where I want it:
and so I used a few of the diagrams above plus some trial and error wiring these until I got it all to work:
and finally working:
I know you are all sweatin the Hello Kitty mouse pad. This is the unfinished wiring diagram that I came up with:
Still want to get my hands on a 1 row switch to have a complete end all be all for these mirror threads.
OMGAH!!!!!! ur the friggin bomb. I THINKG THIS IS EXACTLY IT! the switch looks just like the one i got. damn. i guess asking honda-tech reall does wory... i was about to give up on the heads on these forums... thanx a lot!
if it isn't too much, could you look at my switch... where i listed all the colors and confirm the same switch or similar... i just want be extra careful. thanx guy. you're so great.
Yup same exact as far as I can tell, all colors match up!
[1][2][3][4][5][6]
[7][8][****][9]10]
1= blue/ yellow stripe = "C" (to relay center)
2=green/ white stripe = "E" (to right mirror angle control)
3=yellow/ black stripe = "D" (to right mirror angle control)
4= n/a = "blank"
5= blue/ black stripe = "A" (to left mirror angle control)
6=blue/ white stripe = "B" (to left mirror angle control)
7=black = "GROUND"
8=yellow/ red stripe = "F" (to both mirrors angle control)
9=black/yellow stripe = "12V POWER"
10=n/a = "blank"
Good luck with this bro, I know this can be a frustrating project since some of the info you find just doesn't make sense or work. Took me some trial and error and I'm lucky I didn't short any of my stuff out in the process. Don't give up on H-T either, some are still trying to spread the love!
[1][2][3][4][5][6]
[7][8][****][9]10]
4= n/a = "blank"
7=black = "GROUND"
10=n/a = "blank"
thanx again. i hope others can use this thread too. and sorry for the homo comment. it's just... i really really needed this... i've been searching and searching... googling... and just gave up and look again. my cars been a project car for too long.... anyways. thanx so much.
88crxsir
01-09-2005 11:48 AM
TurboEG6
03-20-2004 03:38 PM
