low beams wont come on but hig beams do
well my loe beans rnt comming on only the high beams. i checked out the fuses but there good and at the same time my dash lights went out any one wats going on or wat to check.
Re: low beams wont come on but hig beams do
replace your bulbs, high beams may work but the lows are burnt out!!! if that dont do it then check to see if your getting continuity to the headlights!
Did all the dash lights go out at once, or just a few? If all, double check the fuses under the dash. Otherwise, just replace the bulbs as needed. For the headlights, just replace them and you should be fine. The bulbs are dual filament, with one for the low and one for the high. So one can be working while the other does not.
Location: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Both your low beams should not have gone out at the same time if the problem was the low filaments in the bulbs! Yes, low and high are on entirely different circuits to different filaments. I put Raybrig fogs on my car earlier this year, they are piggybacked to the low beams, so I am trying to remember if there is a low beam relay with the original setup or a second fuse. It is 3AM so I am not going out to look. Sorry! The dash lights? That may be a clue. Good luck.
For the dash lights, check the dash fuse as mentioned, as well as the dimmer switch in the dash (very common problem).
just checked my bulbs an there still good, if its the switch can i buy it from honda or should i just go to a jubk yard?
i had the exact same problem on my DA...it was the switch, i opened it and some things where loose inside the switch..put everything back on and done the lights worked..$0 for the repair....ohhh and i bought that DA for $1k because seller couldent fix that problem lol...sold it 1 month later with that problem fixed for $2k...
a wire may have come unsoldered from the switch on the column where the headlight arm connects to... i had the same problem on my toyota but reveresed...high beams didnt work
resolder the wire and should work
did you check the bulbs??? if they are good it could be a headlight switch. and double check the fuses to see if the dash lights are just a blown fuse.
Johnmadsen
04-15-2018 06:27 PM
jonny11844
02-23-2014 05:14 PM
FnkyChnkyMnky
06-20-2002 02:21 PM
