need help to install ek foglight???
Old 08-16-2009, 04:34 PM
n0lov3's Avatar
Default need help to install ek foglight???
i install everything, but there 1 white single wire with a brown connector?? i dont know where to connect it at?? so my fog is not workling. the connector is located with the switch harness. any idea wat am i talking about if so i need help??? thanks
Old 08-16-2009, 05:35 PM
b.YipPy's Avatar
Default Re: need help to install ek foglight???
this thread might help you...
http://www.hondacivicforum.com/forum...ad.php?t=61880
Old 08-16-2009, 08:02 PM
ifIexplode's Avatar
Its a power wire, It plugs into your fuse box, In the seconds plug from the left on the top if your looking at it from your driver seat. Is the car 96-98 or 99-00?
Old 08-16-2009, 08:05 PM
ej8ster96's Avatar
what he said
Old 08-16-2009, 09:54 PM
n0lov3's Avatar
99-00
Old 08-16-2009, 10:00 PM
Master Detailer
98civdx's Avatar
why did you make 2 threads?
one not good enough?
Old 08-16-2009, 10:02 PM
n0lov3's Avatar
oh my bad though my bro didnt post is in so i went and do another one
Old 08-16-2009, 10:03 PM
n0lov3's Avatar
so is the foruth one u said
Old 08-16-2009, 10:17 PM
Master Detailer
98civdx's Avatar
yea im 90 ish % sure, i havent put them in forever and i dont remember,
but i think thats the one honda says is the one,
Old 08-17-2009, 10:14 AM
n0lov3's Avatar
here are some picture. the red is for the power the black is for ground and the white with the one pin connector connect it where?? i try the second and the frouth one under the dash and is nott working??? any other idea??
Old 08-17-2009, 10:54 AM
Master Detailer
98civdx's Avatar
there is another one of the brown things by your windsheld washer resiovr, is it connected? kind of behind it.
check all grounds,
try it in all of the plugs.
Old 08-17-2009, 12:57 PM
ifIexplode's Avatar
Id recheck your grounds. Also the plug that is prewired and comes out on the passenger side fender maybe loose, The pin inside the connector was loose on mine. Get a multi meter and see if your gettin power to the Harness that plugs into the fog lamp itself.
etexwagon
05-09-2010 12:24 PM
DOHCtorEK
10-29-2009 10:37 PM
haggis
07-09-2008 09:01 AM
92integ
02-06-2003 10:22 PM
Quick Reply: need help to install ek foglight???
