b20 swap question!!!!
hey wats up i got a noob question
i have an eg an im thinking of getting a b20 engine
into it and i was wondering what is all the parts u need to get!!!
so can u guys tell me more info lol thanks
Re: b20 swap question!!!!
everything for you d15 will swap over to the b20 [besides of course the ecu mounts tranny shift linkage axles....]
sensors and mount are interchangable but you'll need the integra "L" bracket for the back [The one that bolts the motor to the firewall]
and i would sugguest getting and integra intake manifold because the crv one wont clear the hood. hope this helps. I just googled it and found all this out for myself...
so no cutting would be needed for the mounts? no new mount positions besides the firewall mount, just different mounts?
what other tranny could you use besides the stock b20 tranny? just wondering cuz i would think there would be better options.......?
how cramped would it be? still able to boost it?
You'd need mounts, shift linkage, ECU, harness, a B-series manual transmission, axles, yadda yadda. B-series swaps drop right in pretty easily. This is a good website that will show you how to do a b swap and a bunch of other procedures. http://www.c-speedracing.com/howto.php
you need a transmission, mounts, axles, Intake manifold. The wiring will match up fine as wel as the sensors. You can also keep your AC as the B20 uses a D series AC Compressor and bracket. The B20 Transmission doesnt work in your car.
