Won't start, main relay clicks while turning over
Old 08-18-2009, 12:56 AM
0to60in5's Avatar
Default Won't start, main relay clicks while turning over
Car is a 98 EX w/D16Z6, Y8 intake/exhaust manifolds, Y8 air intake. OBD2a->OBD1 jumper harness with a P28 ECU. Stock OBD2 engine harness with a jumper harness I made so that I could plug the Z6 dizzy into the stock harness. Now I had the car running, ran fine. I shut it off went in. Came back out later and turned the key and the main relay was clicking like crazy. Turns over but won't start. Pushed it down by the garage after the battery went dead from me trying to figure it out up by the house. Let it charge for a bit and then tried it again and then the main relay would only click while turning it over. When you first turn the key on it acts normal, main relay clicks on and off, check engine light comes on and goes off like normal but when you turn it over the main relay starts clicking rapidly. First time I ever converted a car from OBD2->OBD1 and it is also my first EK so I am wondering if anyone else has had a problem like this and what I need to do to get it back on the road(then for sale so I can go back to EFs). Thanks.
Old 08-18-2009, 07:31 AM
0to60in5's Avatar
Default Re: Won't start, main relay clicks while turning over
Nothing? Any help would be appreciated. I need to get this thing on the road.
Old 08-18-2009, 08:10 AM
92ehatch's Avatar
first, i would test someone else main relay if you can.
then i would look into the wiring
Old 08-18-2009, 08:11 AM
gsrpedro's Avatar
the main relay is bad
Old 08-18-2009, 08:14 AM
Former User's Avatar
Does the engine crank but not start? Are you sure the main relay is clicking when the key is turned to ON(III)? Might the clicking actually be coming from the starter solenoid? If so, pull the starter out and have it tested.
Old 08-18-2009, 09:09 AM
Nocturnal's Avatar
What happens if you kick the area where the main relay is? My car is weird in that you have to sometimes kick the area where the relay is while I hold the clutch down and my car is in neutral in order for it to start. Otherwise it won't start.
Old 08-18-2009, 11:39 AM
EG'SUS's Avatar
Check if ur starter is grounded.. Thats what mine was doing so then i looked by the starter and a lil black wire was loose... I grounded the wire and it worked
Old 08-18-2009, 01:22 PM
0to60in5's Avatar
The car turns over but does not start. It is most certainly the main relay making the noise. All my grounds are good, no fuses are blown. Not getting spark. :-/
Old 08-18-2009, 01:31 PM
Okay, you don't have spark, there are no fuses blown, and the grounds are good. Does the fuel pump prime?
Clarification: Did you check fuses 44, 31, and 13? Did you check the ground on the thermostat housing? If all of those are fine, then try replacing the main relay as has been mentioned.
Old 08-18-2009, 01:37 PM
EG'SUS's Avatar
Oh, nvr mnd then.. Like everybody is sayin try a new relay, that sounds like ur best shot
Old 08-18-2009, 06:25 PM
0to60in5's Avatar
Well I ordered the new main relay. We'll see. That was my initial thought but I wanted others' opinions. Guess we shall see tomorrow.
Old 08-19-2009, 01:55 PM
0to60in5's Avatar
Replaced the main relay, switched dizzys. Does the sameeee thing no matter what. ECU?
Old 08-19-2009, 02:31 PM
Is the CEL on? Does it stay on steady with and without the service connector jumped?
Does the fuel pump fail to prime when the key is turned to ON(II)?
Do you still lack spark?
Old 08-20-2009, 04:15 AM
92ehatch's Avatar
timing? did your belt jump teeth? or break?
Old 08-24-2009, 03:19 PM
0to60in5's Avatar
Yes
Fuel pump DOES prime.
Correct, no spark.
Also, I have looked over the jumper harness and it looks okay, opened up the ECU and it looks okay visually from what I can tell.
Old 08-24-2009, 05:10 PM
Remove the distributor cap and turn the key to ON(II). Do you measure battery voltage at the Blk/Yel wire attached to the coil and the igniter unit? If so, what voltage do you measure at the Yel/Grn wire attached to the igniter unit?
Old 08-24-2009, 08:15 PM
skaternak's Avatar
ground....
dturbo
08-29-2010 12:29 PM
Acidcrakker
09-03-2007 08:51 PM
biggee
07-04-2007 11:04 PM
B16aSir2
29
07-30-2006 10:53 AM
Civic Hx-T
03-25-2004 06:07 PM
Quick Reply: Won't start, main relay clicks while turning over
