O2 sensor fault.
Old 08-17-2009, 11:30 AM
New User
ramseybd6's Avatar
Default O2 sensor fault.
I recently bought a 1997 honda civic DX. It failed smog and gets poor mileage (29 mpg). Check engine light came on, O2 sensor slow to respond bank 1 sensor 1. Replaced O2 and no difference. Took the car to Honda and they said bad O2 sensor, so I purchased one from them and installed it. Still the same problem. The car also seems to bog down between 2500-3500 rpms which the smog shop also noticed while it was on the machine. The smog guy commented that when the engine bogged down the CO went up considerably. I have also changed out the map sensor and spark plugs and that did nothing. Any help or ideas would be appreciated.
Old 08-17-2009, 11:41 AM
Former User's Avatar
Default Re: O2 sensor fault.
Also change the plug wires, cap, and rotor and set the ignition timing to spec using a timing gun.
What specific OBDII O2 sensor is being thrown? This code could be due to a problem with the wiring or even the ECU.
Old 08-17-2009, 11:54 AM
New User
ramseybd6's Avatar
The code was bank 1 sensor 1 which is the O2 sensor on the manifold. I first replaced it with a cheap bosch unit but when I took it to Honda afterwards they said replace the O2. So I bought a genuine honda O2 and installed it but that did not work either.
Old 08-17-2009, 12:01 PM
Code P0133, right?
You probably have an exhaust leak.
Old 08-17-2009, 12:11 PM
New User
ramseybd6's Avatar
I do not hear an exhaust leak. Would a very small leak still cause this problem and if so how do I locate the leak if I can not hear it? Would a bad catalytic converter possibly cause this problem?
Old 08-17-2009, 12:14 PM
A small leak could cause this problem. Start by checking for a crack in the exhaust header and a leak from the header gasket. Then work your way down the exhaust system to the secondary sensor.
Old 08-17-2009, 12:19 PM
New User
ramseybd6's Avatar
How do I detect a leak that I can not hear. Soap and water or snoop would not work because it would evaporate too quickly.
Old 08-17-2009, 12:20 PM
Anon51's Avatar
have you tried to do a tune-up?
does the cel come on immediately after you turn the car on or does it take a while?
Please find out the code.
also why are they hooking a smog machine to your 97 DX? it should be an OBD2 Inspection which hooks into the DLC port on your car which is connected to your ecu.
not trying to stray from the problem but 29mpg is a whole lot better then what i get :/
5-10mpg give or take.
Old 08-17-2009, 12:24 PM
New User
ramseybd6's Avatar
I did replace the spark plugs and map sensor aswell. I will replace the plug wires, cap and rotor and the coil today. The mileage used to be 34-36 mpg before the cel started coming on.
Old 08-17-2009, 12:27 PM
An exhaust leak near the primary O2 sensor would also reduce gas mileage. Replacing ignition system components is always a good idea to keep the engine running well, but is unlikely to solve the O2 sensor code.
Mfkafka
Honda CR-V & Element
03-12-2013 12:19 PM
hatchinprogress
21
01-23-2005 08:05 PM
cu3tip
10-18-2004 08:26 PM
97civicdx
09-03-2003 12:49 PM
djtech
02-04-2003 03:28 PM
Quick Reply: O2 sensor fault.
