Del Sol Wiring Question OBD2a
Re: Del Sol Wiring Question OBD2a
Nope. Your Del Sol has a 2-piece harness (engine to shock tower plugs and shock tower plugs to ECU/under dash plugs), where the '96-'98 Civic has a 1-piece harness (engine straight to ECU/under dash plugs).
you can. you'll just have to either remove the other one or just tuck it up somewhere. i have all mine tucked under the battery for now.
you can.
i have a one piece rywire for a b16 running straight from the engine to the ECU.
i can't imagine why the dash wouldn't hook up keeping the OBD the same.
Just use the harness you have and then run 2 wires for vtec!
And change your Ecu of course jumper harness and p28 would be my choice.
Thinking to hard man! Use what ya got.
Seagull Management
No, it just doesn't work that way. The underdash harness on '92 - '95 Civics, '93 - '97 Del Sols and '94 - '01 Integras comes out through the firewall to the shock tower plugs and actually all the way up the passenger's headlight and horn. It doesn't unplug from the engine harness by the ECU like on a '92 - '00 Civic.
Seagull Management
Yes, but you may have to repin the IACV wiring at the shock tower and there are no pinouts online for this, it's such a rare setup that doesn't often come up when doing an engine swap as it only affects '96 - '97 Del Sol S and automatic Si models.
I have a
96 del sol. I just called a friend and told him to build me a wiring harness for my setup and was done! Either keep pulling your hair out or just call someone to fix you up. I'm running a h2b setup in my though.
Who is pulling hair here? Im asking NORMAL OBD2 question. If your Info was something I really wanted to take to heart I would. But Im not.. I would really think hard before you post. Im not a Noobie and dont have to "CALL A FRIEND" to build me anything. I can do it myself. Thanks for you replies. But YOUR NOT helping.
b20delslow
07-25-2018 07:44 PM
stiffinEK
11-22-2009 04:49 AM
Boston_George
04-01-2006 05:41 PM
