Car will not go into gear/move
Okay, more problems. 94 civic coupe b16a with LS trans.
Was at a stop light, went to put it in first, car wouldnt move, just revs.
I can move the shifter around through where the gears would be but there is very little resistance if any, and there are no gears there, the shifter just flops back to where neutral would be.
Shift linkages are present and connected, i can hear the linkage moving the pin for the trans I believe.
Clutch and flywheel are new ~1500 miles ago
Axles are in, dont appear broken or anything, but i can spin one wheel and the other wheel will barely turn the other direction, very very slowly.
Prease help
Prease help
Re: Car will not go into gear/move
slave cylinder.
( i believe thats the name of the part) Sits on the belhousing of the tranny. Plunger looking part that moves the throwout bearing.
I had that happen in downtown atlanta during rush hour.. it was a perfect end to a already crap day. Slave cylinder stopped working and the fork wouldn't move. Do you have any idea how long it takes a tow truck to get you off the interstate during rush hour..
Okay, Had a friend push the clutch while I watched the fork/cylinder and it does move/function correctly.
Any other ideas?
Any other ideas?
did you pull back the boot and see if it was moving the fork? the little ball on the end of the rod could have slipped out of the fork's notch, or the fork is broken. Mine didn't have any fluid leaking when it happened.
Could be a bad clutch tho i doubt it being so new. Did the kit come with a new bearing? Could be that, or even the pressure plate bolts maybe loose, did they get torque to the right specs? If the fork is working and the pushrod is set properly on it those are the only things i could think of that would cause you to not be able to select a gear. I'm still kinda leaning to grumblemarcs idea of a broken fork tho.
This broken fork? is this referring to inside the transmission itself?
Do you think it could be an internal problem?
Sounds internal. If the linkage is good, the clutch is new, the slave cylinder is working, it has to be internal. Possibly a broken shifter fork. The fact that the shifter just flops back to neutral, that wouldn't really happen if the clutch wasn't releasing. The more I think about it the more I think its the shifter fork.
Yes if it is a fork it would be an internal issue. You can pull the boot back and kinda see the fork a little bit but it is inside the housing.
Here is a video of the shifter movement
http://www.youtube.com/watch?v=G8NBAj2ADCY
If this help any?
If this help any?
Well, looks like ill be looking for a new transmission..
Resident Gearhead
Did you use a spring pin to connect the linkage to the shift rod?
If it is the tranny, this will give you a chance to get a better one. A B18B tranny on a B16A isn't ideal.
Im certain the linkages are correct, ive swapped a few motors myself and never been beaten by a linkage, and yes bitch pin was used..
I have an LS trans because the car will be boosted as soon as this is all sorted, and I enjoy the longer gears.
coachkellum
09-09-2004 02:03 PM
