valve chatter and white plumes of smoke?
Old 03-18-2011, 08:28 PM
jdmfanboi87's Avatar
Default valve chatter and white plumes of smoke?
so recently, I think I have been getting some valve chatter but cant tell for sure. It usually happens when from a cold start and also I believe I've been burning a massive amount of oil. After start up and I begin to drive not only do you hear what I believe is valve chatter but plumes of white/blueish smoke coming out of my exhaust. I have a 97 civic dx/D16y7. Any solutions? Usually the smoke goes away once the engine is warm...have no idea what could be causing this, my only guess is the mileage...well anyway, I wanna do a y8 swap but kind of scared because if its not the y7 head causing me to burn oil then I have no idea what it is!! any help would be nice.
Old 03-18-2011, 10:42 PM
Master Detailer
98civdx's Avatar
Default Re: valve chatter and white plumes of smoke?
For the chatter, adjust the valves.
For the burning oil, do a compression check, and post the numbers. It is likely the rings.
The while smoke, is most likely just water in the exhuast, which is totaly fine.
Old 03-19-2011, 09:55 AM
cool thanks for the info. I will get a compression test done as soon as I can. sorry forgive my ignorance, how would water get into my exhaust?
Old 03-19-2011, 10:34 AM
Master Detailer
98civdx's Avatar
Hot, cold, hot, cold=Condensation=Water in pipes. when that heats up, it turns into steam, and that's what you see coming from the exhuast.
It "could" be a coolant leak/burning coolant/bad HG.
Is there any coolant/oil mixing? Does the car overheat?
Old 03-19-2011, 12:15 PM
hey thanks for the explanation. i thought it could be condensation but wasn't too sure so thanks or clarifying. and no my coolant seems to be ok, my levels are always constant and the car is not over heating. Once I have some time I will get a compression test done but Im guessing that it could be the rings, i doubt they have been changed...the car is sitting at 172,xxx miles anyway.
Old 03-19-2011, 12:23 PM
Master Detailer
98civdx's Avatar
No problem.
172k, isn't much for a honda.
Legacy75
03-12-2017 11:24 PM
Mfoehrkolb
10-23-2008 05:45 AM
blackmfoggie
09-07-2007 07:34 PM
SixPAK
06-03-2003 12:28 PM
snoop_bealybob
10-05-2002 10:16 AM
Quick Reply: valve chatter and white plumes of smoke?
