map sensor code/problems
Old Mar 19, 2011 | 02:44 PM
hondalove414's Avatar
Default map sensor code/problems
I got a cel for a map sensor and I got one from my buddy and I know it works. I put on the car starts idles to 2000rpm and then just drops downs fast and dies. But with mine the car starts rough then starts ideling at 1100 rpm and that's the same time the cel comes on. And when I drive the car has no power under 2500rp just bogs and sputters but fine after 3000rpm
Old Mar 19, 2011 | 03:13 PM
Former User's Avatar
Default Re: map sensor code/problems
Do you get a CEL with both ECUs?
Old Mar 19, 2011 | 04:40 PM
yea
Old Mar 19, 2011 | 04:44 PM
What specific codes with each ECU?
Old Mar 19, 2011 | 04:48 PM
Why do you keep asking about the ecu. Just wondering because I never mentioned it. But I changed it to see if the codes would go away.
Old Mar 19, 2011 | 05:05 PM
grumblemarc's Avatar
The Grumpiest
Because if you swapped the MAP sensor with a known working one then it goes to reason the MAP is probably not the issue. Therefore you need to start looking elsewhere.
So to answer Ron's question. Do you get the same codes with the 2 different ECU's or are they different codes?
Old Mar 19, 2011 | 05:27 PM
ok my ecu is a jdm P30 and I swaped the map sensors and my car didt start. Put the old map sensor back on and had the rough start then went to my buddys and pluged his p28 that he used on his b16 but I didt change map sensors or check the codes.
Old Mar 19, 2011 | 07:35 PM
lazlong's Avatar
MAP code and a high idle indicates a possible vacuum leak.
Old Mar 19, 2011 | 07:38 PM
Car idlesaround 1100rpm
Old Mar 20, 2011 | 08:11 AM
Bump taking the car to a local shop tomorrow
5_Lug_B
Jul 17, 2007 04:32 PM
Punker1234
Feb 4, 2006 01:20 PM
chrysler kid
Sep 28, 2004 07:24 PM
slowazzhatch
Jun 1, 2003 07:42 PM
