1993 honda civic lx not starting pleassee helllpp
my girls 1993 honda civic lx automatic d15b7 it ran great this morning turns on everything the moment she gets out of work it doesnt start .. it wasnt getting any power at all i replaced the battery checked fuses check relays everything pleassee helpp any advise is greatly appreciated! thankk you
Re: 1993 honda civic lx not starting pleassee helllpp
nothing at all no lights no power to anything i thought it was the battery so i replaced it and nothing still not even a beep
On both sides of the fuse you have 0 volts? If so, double check battery terminals for voltage. If you have voltage at the terminals and zero at the 80 amp fuse, it tells me there is a break in the positive battery cable.
okay theres one thing that stands out white wire that comes off the pos terminal to the fuse box has a small part of it broken out of the terminal but most of it is still in the terminal.... thats bout the only break i found
and she has been having issues with her speedometer i replaced the cluster and the speed sensor idk man im frustrated im debating on just re doing the whole harness..
speed sensor- Clean the plug on speed sensor i had the same issue once.
battery- have you checked the alternator
Cubafrmdanycs
06-26-2016 10:28 AM
c for sea
21
08-12-2005 06:38 PM
