mini-me swap, obd2a to obd1 help
Sup all, to start this off, I got a d16y7 block with a d16z6 head. D16y8 intake manifold.
Right now I have the y7 throttle body on because if the 3 wire iacv.
I cut the two wires from the 3 wire (left the orange alone) iacv plug and connected them to the iacv valve behind the manifold and changed the throttle body to a d16z6. I have the jumper harness from obd2a to obd1. Problem is when i try to run the p28 my car bogs out. I've used different ecu's, checked the sensors, tried using the y7 tb and blocked off the iacv valve on it and nothing works.
My car runs perfect with the y7 tb and the p2e ecu but when I try to go obd1, my car runs like crap. Any ideas why?
Re: mini-me swap, obd2a to obd1 help
Thx for help all. Think I found out what was wrong. My v-tec isn't hooked up so maybe that's why my car runs retarded. Will hook it up soon and try the conversion again.
"One small step for man, one giant leap for man kind". Let us know what happened. every car back on the road equals a happy human.
VTEC not being hooked up would't make you car run like ****, VTEC just wouldn't work and you would have a check engine light.
Hmmm.I believe that's correct for a obd2 motor.but if the motor is obd1 and your putting it in an obd2 car I think you gotta change em.so you might be ok.keep us updated.
I FOUND THE PROBLEM. it runs the p28 like **** with a virgin ecu. I ran my friends p28 that he has tuned to his lsv all motor and my car was BEAST. So now I'm gathering money to get my **** tuned and have it beast mode. Gonna chip it with Chrome.
Unmexicano
03-15-2011 07:00 PM
phatrick2332
10-07-2008 04:33 PM
