Help!!! ZC SOHC non vtec idle!
swap a ZC in my 4dr; idle surge up and down from 2000-1000; IAT sensor Changed IAC sensor Changed and cleaned all hose plug clamped on no leak. maybe its because im running a y7 ecu? should i switch to the ZC ecu?
Re: Help!!! ZC SOHC non vtec idle!
Have you tried plugging the holes on inside of your throttle body with your finger? The top one goes to your Idle Air Control Valve and the bottom hole goes to your Fast Idle Thermo Valve. Try plugging each one or both and see what happens to your idle. If it corrects, then you found your problem.
Low antifreeze can also cause a erratic idle because of the air bubbles in the system. Have you checked your coolant level? Do you have enough coolant in your overflow incase you are low?
by the way just to see if ur throttle cable is not improperly adjusted, when ur car surges put ur foot under gas pedal and pull up to see if idle goes back, if so then readjustment tension on idle, same happened to me
CRXguy_88
09-23-2010 06:11 AM
b18hondahb
16
10-13-2006 05:40 PM
