b16a2 into a 1998 civic ex
Old 03-20-2011, 10:18 PM
Espyone's Avatar
Default b16a2 into a 1998 civic ex
Hi Honda Tech,
I bought a complete 1999 em1 that was hit in the back and it was not drivable, because of the rear quarter panel was toast. I am going to do a stock swap. I want to swap the b16a2 into my 1998 civic ex.
Should there be any concerns I should look for. I think I have the basic knowledge of the swap down, but not sure about if the harness will plug and play.
I have read and also looked in the helms manual the ckf sensor/plug is a 3 wire on the my 1998 civic and the 1999 em1 has a 2 wire sensor/plug.
Is there any other electrical or mechanical concerns?
I was also told I need to buy a obd2a to obd2b wire harness jumper to the ecu. Is that correct?
I have the whole front end and it is all stock. So any info on what I need to transfer besides the Engine,Tranny,Engine harness,ECU Axles, Air box.
Reason I want to do the stock transplant at first is to get it bard in cali. After that I want to do upgrades. This is my first swap and hope this can go very smoothly. Please educate me on any other things.
Thanks you!
Old 03-21-2011, 03:56 AM
The Grumpiest
grumblemarc's Avatar
Default Re: b16a2 into a 1998 civic ex
Did you check the FAQs? A few swap links to be found there.
Old 03-21-2011, 06:05 AM
WREKD em1's Avatar
If you bought a complete wreck you should have everything. I'm currently doing the same thing. 99em1 to 00 ej8. The em1 is a wreck, passenger side crash. But car still runs so verything is transferable to ej8 body. Engine, trans, axles, wiring, ECU , suspension, brakes, interior, etc.
Old 03-21-2011, 06:57 AM
ekVic214's Avatar
dont forget the mounts and use the si rear t bracket too
lonely_driver4
01-18-2019 09:54 PM
wolf95
31
12-15-2011 02:36 PM
Espyone
10
04-13-2011 10:27 AM
donvito#1
03-14-2008 09:31 AM
Quick Reply: b16a2 into a 1998 civic ex
