b16b b18c oil pan
Old 03-20-2011, 06:24 PM
egstance's Avatar
Default b16b b18c oil pan
I am doing an engine swap into my eg and im either putting in a b16 or b18 i would much rather have the b18 but does anyone know how much closer the oil pan is going to be to the ground??? My car is slammed and sits very low to the ground.
Old 03-20-2011, 07:24 PM
NotAJDMFanBoy's Avatar
Default Re: b16b b18c oil pan
The B16B and B18C use the same block, just a different crank, rods, pistons, and head. So no difference.
Even if you were debating B16A vs B18C or B20 or B18 LS, your crankshaft will stay in the same place since it has to mate to the transmission in the same place. The oil pan may be a little taller or shorter on one or another, but not much.
Either raise the car or make a skid plate if you're concerned.
Don't even ask about going K, H, or J series if you're concerned over ground clearance since they sit lower.
Old 03-21-2011, 01:38 PM
egstance's Avatar
Oh ok thanks. What all am i going to need for the b18c swap i know engine mounts of course but what else do you know of some kind of guide?
redludeshohio
05-01-2012 10:19 AM
cslegacy
03-23-2009 05:51 AM
turbo*s2k
03-22-2005 05:45 PM
JDMHN8
09-28-2003 06:33 PM
oneslodx
07-13-2003 10:19 PM
Quick Reply: b16b b18c oil pan
