Hub Removal Help...
Hub Removal Help...
Ya so today i was trying to put in my skunks 2 studs, and i get the caliper off and the rotor off, no problem. but then i try to take the big nut off the center of the hub and it wouldnt move a tic. Any Suggestions how to get it off?? I had a huge breaker bar on it, with me standing on that, jumping up and down... Help y0
Re: Hub Removal Help... (blaster834)
bigger bar, impact gun, lift the front end of the car up wedge the bar on the ground and put it in gear (never tried that one though)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 »</TD></TR><TR><TD CLASS="quote">Ya so today i was trying to put in my skunks 2 studs, and i get the caliper off and the rotor off, no problem. but then i try to take the big nut off the center of the hub and it wouldnt move a tic. Any Suggestions how to get it off?? I had a huge breaker bar on it, with me standing on that, jumping up and down... Help y0</TD></TR></TABLE>
If I can't break it jumping up and down on the bar (it flexes too much 200 pounds, lol). I just take lock the steering wheel, get in a good position, and pull with both hands down as much as I can. This way I never ran into problem with breaking them loose. I can even break those huge 36mm axle nuts on my car this way (3ft breaker bar).
2004.10.3
My friends and I broke 2 half inch sockets and a 3/8 head breaker bar trying to get a hub nut (driveaxle nut) off of an Integra. I cut my hand on one as well... ouch!
ANYWAYS, we used tissue paper inside the axle socket along with a 1.5" diameter axle nut breaker specialty tool from SEARS and then put a 6' long fence post over the end to break the Integra nut loose... and that was 4 guys together, 2 pulling up and 2 pushing down before it finally just b-a-r-e-l-y budged and broke loose.
Hopefully your axle nut will be much easier... try an impact gun with socket if it doesn't come off by hand. That's my best suggestion (and yes, my pals and I did try an air gun... that only stripped out the socket we had!)
hang on, you hammered out that part of the nut that's dented in to keep it in place right? I'm tired so forgive my discription, spelling, etc but whatever yuo all know what i mean
Re: Hub Removal Help... (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">you mean the axle nut?
thats a bitch</TD></TR></TABLE>
your a lot of help :rollseyes:....use a bigger breaker bar the longer it is the more leverage you hav on it.. good luck bro
Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 »</TD></TR><TR><TD CLASS="quote">Ya axel nut is what i am talking about
yea we all knew that.(not tryin to be a smartass)
Re: Hub Removal Help... (ek9800)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 »</TD></TR><TR><TD CLASS="quote">
your a lot of help :rollseyes:....use a bigger breaker bar the longer it is the more leverage you hav on it.. good luck bro</TD></TR></TABLE>
shut the **** up stop stalking me...and im sure he didnt know he needs more leverage ":rollseyes:"
shut the **** up stop stalking me...and im sure he didnt know he needs more leverage ":rollseyes:"</TD></TR></TABLE>
yea im stalking you cuz im auctually helping someone instead of saying "axle nut thats a bitch"..get a life and stop being a little post *****
no youre stalking me cause every time i post you quote me saying some dumb **** cause i put you on my block list cause youre a ******* retard
