Car wont start help!
Heres the problem I started up my car and it started up fine... I put into reverse and it moved about an inch and the motor turned off.... I get a check engine lite and now my motor wont turn over... It tries to but it wont turn over it sounds like its not getting any fuel but i dont know wat to do. I tried to jump the ecu and it wasnt able to ... there were 2 plugs one w/ a green and brown wire and one w/ a blue and some other color wire and i stuck a paper clip into each of em tryin to jump the ecu one at a time and its not workn
Re: Car wont start help! (eg6si)
when i turn the key to on am i suppose to hear something ? Cuz when i turn it all the way on i dunt hear anything and when i try to turn it on it just tries to turn over
but its not... could it be ignition ?
Re: Car wont start help! (simplypinoyy)
yeah usually you are supposed to hear fuel pump priming, if you don't turn your key to the on possition kick your left kick panel (where the fuses are) and see if it starts.
I had a same problem the other day, sitting in my driveway idling, after checking i had spark and fuel, it turned out to be teeth broken off on the timing belt which made it not start.
Re: (mnskateboarder)
hey in the 92 civic hb is there fuses for the fuel pump ? and also i heard that if the distributor had gone bad that it causes the ecu to not send fuel to the motor... which i may think is my problem and also I cant find the fuse for the fuel pump under the steering wheel panel
Re: (simplypinoyy)
I just tried to change the distributor thinking thats the problem but theres no use .... still no spark, what else can be causing this ?
Re: (simplypinoyy)
Heh sounds like what happened to me, only I have spark and fuel. Checked the timing belt last night and it looked fine. I don't know whats going on with mine, good luck with yours though.
Re: (ImportsCRX)
wholy **** that thing is still not fixed?
you should take basic electrical class or something it will help you save time next time that thing happens.
Re: (Top-Fuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportsCRX »</TD></TR><TR><TD CLASS="quote">no areil, I think it's the main relay, you thought it was your dist, ecu, girlfriend, ect ect *sigh* should of listened to me long time ago lol</TD></TR></TABLE>
yeah ok yeah rite ray thats y when I replaced it it didnt work... Still nothing, changed main relay, ecu, distributor still no spark... someone suggested Crank Position Sensor... does the d16z6 even have one? i tried to look at where someon told me it should be i didnt find it....
Re: (simplypinoyy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplypinoyy »</TD></TR><TR><TD CLASS="quote">
yeah ok yeah rite ray thats y when I replaced it it didnt work... Still nothing, changed main relay, ecu, distributor still no spark... someone suggested Crank Position Sensor... does the d16z6 even have one? i tried to look at where someon told me it should be i didnt find it....</TD></TR></TABLE>
It's in the dizzy (it's actually cam position sensor). If you are still getting no spark then I don't know. how do you check for spark, where did you get the dizzy?
Re: (ABK)
Did you ever check the code? It's a Blue clip near your ecu. You have to stick a paperclip into both sides to jump it then count the flashes. Once you tell us what the CEL is we can help you diagnose the problem. How did you check for fuel? Did you take the banjo bolt off the fuel rail? Do that and make sure you actually have fuel to the fuel rail cause my problem turned out to be a clogged fuel filter. Last time you filled up did you run your car to the point where it was past E?
Re: (simplypinoyy)
ok ariel, i changed the main relay for you....you didn't change it yourself. Hell, you didn't even know where it was located or what it looks like before i told you
Re: (ImportsCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportsCRX »</TD></TR><TR><TD CLASS="quote">ok ariel, i changed the main relay for you....you didn't change it yourself. Hell, you didn't even know where it was located or what it looks like before i told you </TD></TR></TABLE>
Blah blah blah ... the main thing is that u were wrong...
Kid-jdm-teggy
08-27-2013 11:49 AM
jaydm ferio
12-08-2006 11:27 PM
