Type R seats in a EK9
I bought some Integra Type R seats and im putting them in my 2000 hatch... The Front fit fine..but the back isnt as easy b/c of a stud and no bolts ... Has anyone else done this before...what have you done,... what do you think
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Swap the rails from your original seats and they'll fit fine.</TD></TR></TABLE>
he's talkin about the rear seats.
Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">Not to thread jack but, will ITR rear seats fit in a 96 civic coupe with no modification?</TD></TR></TABLE>
if you have 4dr ITR seats.. for a hatch you need to swap out the frame of the seat.. you need to take the foam and skin as one off the frame and swap frames.. takes time but its cake. or you could do it the ghetto way and drill out the thread on the outsides where the brackets bolt in.. but do it right.. trade frames.. looks real clean when done right.
Re: (DOHC4life)
ITR 4 door rear seats(DB8) will fit into a coupe with some modification. The bottom of the seat fits in fine w/o any problem. However, the top part is wider and you must either cut your rear quarter panels to have it fit in...or you can rewrap the backrest part on you existing oem seat.
Re: (96ex)
Just take the skin and foam off the ITR's and put them on your EK rear seats. They fit perfectly fine. The rear seats metal frame is the same. The only difference is the Mountings holes.....
Thrifter
10
12-22-2012 01:59 AM
Caretaker
08-04-2004 06:57 PM
