Easiest Way to Pull Out Car Stereo from 92-95 Civic
Old 10-03-2004, 08:48 PM
hybridhonda826
Guest
Posts: n/a
Default Easiest Way to Pull Out Car Stereo from 92-95 Civic
I need to check the back of it to see if there is a aux input to connect my ipod.
Old 10-03-2004, 09:08 PM
hybridhonda826
Guest
Posts: n/a
bump
Old 10-03-2004, 09:09 PM
suspendedHatch's Avatar
Default Re: (hybridhonda826)
This thread sounds too much like a "teach me a good way to steal ****" thread.
Old 10-03-2004, 09:11 PM
skip.two's Avatar
Default Re: Easiest Way to Pull Out Car Stereo from 92-95 Civic (hybridhonda826)
*yawn* IBTL
Old 10-03-2004, 09:30 PM
hybridhonda826
Guest
Posts: n/a
Default Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">This thread sounds too much like a "teach me a good way to steal ****" thread.</TD></TR></TABLE>
no this is for my own car
Old 10-03-2004, 09:34 PM
Luserkid's Avatar
He has a point.
If its a aftermarket then take it out the same way you put it in but opposite.
Old 10-03-2004, 09:39 PM
hybridhonda826
Guest
Posts: n/a
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
He has a point.
If its a aftermarket then take it out the same way you put it in but opposite. </TD></TR></TABLE>
the car came with the aftermarket stereo
Old 10-03-2004, 09:47 PM
92 EH2's Avatar
just buy i-trip, its liek 40 bucks, it connects to your i-pod adn then you set yoru radio to like 87.9 and it plays yoru ipod
Old 10-03-2004, 09:48 PM
SOHC4life 96's Avatar
Default Re: Easiest Way to Pull Out Car Stereo from 92-95 Civic (92 EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 EG6 &raquo;</TD></TR><TR><TD CLASS="quote">just buy i-trip, its liek 40 bucks, it connects to your i-pod adn then you set yoru radio to like 87.9 and it plays yoru ipod </TD></TR></TABLE>
Theres an idea.
Old 10-03-2004, 09:51 PM
McNizzle's Avatar
that was my first thought EXACTLY
no offense, but even if your not doing bad things this could help a lot of people do them
Old 10-03-2004, 09:52 PM
Dacalac's Avatar
Default Re: (Chris M)
there also is a car audio/security forum on HT.
but I doubt they would know anything about this though.
Old 10-03-2004, 09:53 PM
Luserkid's Avatar
Hey you know what, your in So. Cal. Get in touch with me and ill pull it out for you no charge. That way everyone can make sure its all legit.
Old 10-03-2004, 09:55 PM
maxrpm's Avatar
Oh like thieves don't already know how to steal a civic stero. Plus they don't care about trying to take the four screws off and neatly unplugging the stero. Civic front panel is so easy to take apart. IMO
hybridhonda826
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Hey you know what, your in So. Cal. Get in touch with me and ill pull it out for you no charge. That way everyone can make sure its all legit. </TD></TR></TABLE>
I live in northern SD county and for the last time <FONT SIZE="18">THIS IS MY CAR OMFG</FONT>
Old 10-03-2004, 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 EG6 &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="5">just buy an i-trip</FONT></TD></TR></TABLE>
Old 10-03-2004, 09:59 PM
queensny's Avatar
I worked on my stock radio today, easiest way is to remove the lower compartment right underneath the readio, there 5 screws you will need to unscrew, 2 will be on the side meaning drivers side and passener side, the other 2 are up which means looking up from the gound you will see them, and the 5th odd ball screw will be located in the ash tray so remove the ashtray and it will be visible (all are philps heads).. hope this helps you
Old 10-03-2004, 10:00 PM
hybridhonda826
Guest
Posts: n/a
Default Re: (queensny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queensny &raquo;</TD></TR><TR><TD CLASS="quote">I worked on my stock radio today, easiest way is to remove the lower compartment right underneath the readio, there 5 screws you will need to unscrew, 2 will be on the side meaning drivers side and passener side, the other 2 are up which means looking up from the gound you will see them, and the 5th odd ball screw will be located in the ash tray so remove the ashtray and it will be visible (all are philps heads).. hope this helps you</TD></TR></TABLE>
this is for a 92-95 right?
Old 10-03-2004, 10:01 PM
queensny's Avatar
yes, mine is a 94,
Old 10-03-2004, 10:11 PM
jdmsiR20's Avatar
if you're legit or you're tryin' to steal someone's ****... you'll figure how to take it
out anyway.
use this.
http://www.installdr.com
and if you aren't legit, i'll just trust that you burn in hell
good luck.
Old 10-03-2004, 10:16 PM
Daniel_san's Avatar
why don't you go on the web to see if your deck actually has aux input
seems allot easier then taking it out and ****
Old 10-04-2004, 02:11 AM
soon2bhatch's Avatar
Default Re: (Daniel_san)
just rip it out.
JDMITRTuner
07-02-2007 05:24 AM
mtwn
Honda Civic (2006 - 2015)
05-18-2007 07:14 PM
BlownH23a
05-12-2007 09:39 PM
3.3.3
03-27-2007 10:25 AM
ToKeNbLcKgUy
08-12-2005 04:57 PM
Quick Reply: Easiest Way to Pull Out Car Stereo from 92-95 Civic
