can't downshift to 2nd...is my tranny busted?
i can shift 1-5 easily. but when i downshift from like 3rd or 4th into 2nd gear, it doesn't want to go in. unless i yank on it HARD. anyone know what's wrong?
Re: can't downshift to 2nd...is my tranny busted? (1.8)
is there any grinding when it does go into gear
tryin flushing the tranny fluid lots of people have had good luck with gm syncromesh and ME personally like honda genuine mtf everytime i get a grind i change the fluid and voila gone
Re: can't downshift to 2nd...is my tranny busted? (screech)
no, there's no grinding at all. i searched and found out people recommend the gm syncromesh but in my case, my tranny isn't grinding. i don't want to spend $40 on tranny fluid.
i've been driving like this for a couple months already. pisses me off but i can't do anything.
well i know that my car will sometimes refuse to go into first with out puttin it in second first and sometimes it wont go into reverse without puttin it in 3rd first but my tranny is strong and there seems to be no problem dont know what to tell you sometimes honda's just dont like to go into gear
i just did a syncromesh trans flush as i had the EXACT SAME Problem as you.... but still not gone yet...
EDIT: how fast are you going to down shift into it... (first of all down shifting is terrible on trannys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote">is this before you put new tranny fluid?</TD></TR></TABLE>
how fast are you going, when you try to down shift into 2nd?
any funny noises coming from the tranny?
cable or hydro tranny?
does it gring going from 1st to 2nd gear, at high rpm(near rev limit)?
it could be many things, busted PP, bad second gear synchro, worn shift fork, etc.. i can tell you from my own experience, that the only two times that i have had this problem has been when i busted my pp. and the other time, was when i installed my shift linkage the wrong way(long story)
are you matching your revs, when you try to down shift into 2nd. do you(bleep) hit the gas, right before you downshift into 2nd. doing that, will make your synchros line up!
Re: can't downshift to 2nd...is my tranny busted? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">are you matching your revs, when you try to down shift into 2nd. do you(bleep) hit the gas, right before you downshift into 2nd. doing that, will make your synchros line up! </TD></TR></TABLE>
yeah what he said, try to rev match.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote">yes, i do rev match. </TD></TR></TABLE>
damm, you got me scrathing my brain. i hate to ask you this, but do you rev match on every other downshift, i.e 5-4, 4-3? you might need to remove your tranny to find out what's wrong, the only thing i can think about is a broken clutch spring(if your clutch has springs), or loose flywheel bolts(but that would affect every gear)
Can you shift from 4-3, and THEN 3-2??
And also, even if you flush the tranny fluid, that's just a temporary fix and won't help much if something else is wrong.
(unless if it's really the case, and you haven't flusehd in 2 years..)
there are a lot of possibilities in your situation.
-You might have to bleed your clutch
-You might need a new clutch slave or clutch master cylinder
-Maybe your 2nd gear synchro is worn
Who knows.. Good luck on finding out, but don't come to conclusions and do things that people on here tell you just because they had the same problem.
It's like somebody telling you to replace your IACV because of a starting problem (which helped them, but not necessarily is going to help you because in your case it may be the engine temp sensor and not the IACV)
Just check it out before doing any work on it. Good luck
Re: can't downshift to 2nd...is my tranny busted? (The HamsterBall)
i know what you mean. i can downshift from 5-4, 4-3, easily. but i can't get it into 2nd gear without yanking on it hard. and yes, i do rev match on every other downshift.
tranny fluid was flushed a couple weeks ago. the clutch fluid i just did about 10 minutes ago but the problem was still there.
i have an extra slave cylinder sitting around i'll probably switch that tomorrow. anything else i should look at?
i'm leaning towards the 2nd gear synchro right now.
how do you rev match? some people think that they rev match but they do absolutly jack ****, besides preventing the jerking.
Re: can't downshift to 2nd...is my tranny busted? (ABK)
this is what i do to rev-match...let me know if it's not correct. i basically rev the motor in neutral to match the rpm to the lower gear that i'm going to be in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote">this is what i do to rev-match...let me know if it's not correct. i basically rev the motor in neutral to match the rpm to the lower gear that i'm going to be in. </TD></TR></TABLE>this quote was taken from a thread in the autocross forum:
REV MATCHING:
When taking off from a stop and then going up through the gears, steps 1,2,6,7 above are the normal shifting method for each gear change. The synchro mesh are more than enough to control the intermediate shaft speed. The engine will passively rev match itself because it slows down naturally and this is appropriate when shifting up.
When down shifting, the engine needs to spin faster as it engages the new gear. This can be achieved by 'blipping' the throttle as the transmission passes through neutral. If the engine isn't manually sped up by the driver, it will be sped up by the driveline when the clutch is re engaged. This can be OK for normal street driving, but if the car is cornering near the limit this can upset the suspension and the tire adhesion.
The synchromesh are usually adequate intermediate shaft control when down shifting one or two gears. Aggressive downshifts (like a 5 2 shift from high speed) can benefit by using double clutch shifting to assist the synchro's. Shifting into first gear in a hard corner is nearly impossible without double clutching (this is useful for those really tight hairpins, especially if they exit uphill).
hope it helps you see if you're doing it right
REV MATCHING:
1. clutch in out of the gear
2. clutch out blip the throttle
3. clutch in, and into gear
4. let out the clutch.
Banned
what tranny?? 92-95 civic tranny's have al shift forks. and they break quite easier than the 6gen steel ones.
well if that slave cylinder doesn't workk.. it might be your synchro
and don't YANNKK it in gear.. if it won't go.. don't force it..
bad for your tranny.
i would say, don't do anything (like canyon runs on passes with a lot of 2nd gear hair pins and curves) with it.. until you get the synchro fixed.
Good luck.
Good luck.
It could be numerous things. It could be something like a warped pressure plate, to bent shift fork. fixing trannies sucks!!!
try bleeding the system, check bushings and shiftlinkage.. If not, then if you can't live with it, I would suggest taking the tranny off and checking out the clutch, Trow out bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote">thanks for all the help. </TD></TR></TABLE>
i guess you'll need to get that tranny off the car, pop the case off and take a look at the second gear synchro. let us know, if you find the cause of your problem!
jimboek
17
04-26-2007 03:48 PM
SimbaDogg
02-22-2004 10:11 AM
ill phil
15
09-04-2002 10:37 PM
