My LS/VTEC project.
Premium Member
My LS/VTEC project.
OK everyone I would like your input. Note: If your reply dosent pertain to my question please do not reply.
My car is a '00 SI
Ive got a B18A1 w/ 70k & B16A2 w/72k
I plan on using the B16 head with the B18 shortblock.
My question is: if I use the B16 pistions I will maintain the 10.2:1 compression, but can I use the rods also even though it will change compression and what would the compression be. Will the LS crank and rod journal bearings all fit and still maintain minimum clearance. I am hoping to be able to use this simply because the cap bolts are bigger by 1mm. Which is great since I am maintaining VTEC. Obviously. I doubt it will work but I want your insight.
Also if you have any other suggestion please add them.
Thanks.
My car is a '00 SI
Thanks.
Electrician
Re: My LS/VTEC project. (nd4sped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd4sped »</TD></TR><TR><TD CLASS="quote">OK everyone I would like your input. Note: If your reply dosent pertain to my question please do not reply.
My car is a '00 SI
Thanks.</TD></TR></TABLE>
you can't you use ls rods w/ b16 crank, gsr rods w/ b16 etc etc. b16 rods, b16 crank. ls rods/ ls crank. but lsblock w/ b16 pistons and b16 head... compression in mid-low 11s check websites for a more accurate specs. i think cspeedracing has an easy calculator to use
My car is a '00 SI
Premium Member
Re: My LS/VTEC project. (dcb16)
I have decided what I am doing...
T3/T40E setup
B18A1 block
B16A2 head
.........3 angle valve job
Eagle rods & pistons (same length and compression as LS componets)
...............unless I get a bigger bore with the Darton sleeves...82mm.
Darton Sleeves (same inner diameter or 82mm)
LS Crank
Golden Eagle LS/VTEC kit
Golden Eagle Girdle kit
GSR Oil Pan
ITR Oil Pump Gear
I think thats about it...
Also I was thinking about getting the crank micropolished and cryo'd...What do you guys think.
T3/T40E setup
B18A1 block
B16A2 head
LS Crank
GSR Oil Pan
ITR Oil Pump Gear
