Keyless Entry Stopped Working
Last night i installed a sony xplod head unit in place of the stock one in my 97 civic ex and now my keyless entry does not work . I think its the headunit causing this...does anyone know how to fix it?
searching would have told you that you need to have the oem deck powered up and still connected to the green harness
you need a special dual harness just for this purpose.
Put the stock deck behind the dash
H-T White Ops
Wire taps are your friend. Or like pdiggity said, get the splitter harness. Either way you're going to have to keep the stock deck in there. Wrap the ****** up in some rags and shove it behind your dash so it doesn't make any ratteling noise.
you guys are silly... there's a better way to install the HU and retain OEM keyless without shoving the factory radio behind the dash
I just ran 4 wires (power, ground, dimmer, and ignition) to the factory radio from the main harness, which connects to my Clarion MP3 player... It still lights up and everything, keyless still retained, but no sound comes out of it....
All I did was use some terminal connectors in place of the whole PIN unit...
Modified by SirSmokeAlot at 3:53 PM 10/3/2004
H-T White Ops
Re: (OldSkoolCiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldSkoolCiv »</TD></TR><TR><TD CLASS="quote">Alright thank you for the help. Now can you tell me where I can get the t harness?</TD></TR></TABLE>
Can be found at http://www.installer.com/wires/wh43K.jpg for $11.90
Part #70-1720T WH-43K
best buy/circuit city would have it too
I actually put mine under the passenger seat, because my stereo is in the lower din and the factory wouldnt fit then
youve been here since april and you already have 2000 posts? ***** much?
Cars and relays arent exactly the same things though.
Why not share what you did instead of being an ***?
H-T White Ops
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">youve been here since april and you already have 2000 posts? ***** much?</TD></TR></TABLE>
Take a look through his watched topics and see what he actually posts. I have YET to see an informative post.
Re: (yanta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yanta »</TD></TR><TR><TD CLASS="quote">LOL.. leave your oem deck.. you guys should'nt touch cars.</TD></TR></TABLE>
actually, if you leave it like I have it (with the stock radio up top), it doesn't look like there's a system in the car, which means less break-in potencial....
but thats right, we shouldn't touch cars...
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">
Take a look through his watched topics and see what he actually posts. I have YET to see an informative post.</TD></TR></TABLE>
aha yes...true
I have the block-off plate up top for my setup and the stereo in the lower din = Also doesnt look like I have a system
aha yes...true
Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">I wanted to move my head unit to the lower part of my console but I couldnt get the screws off of the old tape player. Oh well, weekend project for me. </TD></TR></TABLE>
I didn't even get a tape player... I had the din slot
GSR-EG-92
Audio / Security / Video
06-15-2009 11:52 AM
ParistsCP
05-07-2006 07:16 AM
