Question about motor mounts
Well, today it was raining pretty bad, and I had my CAI on, cause I forgot to put my short ram in my car, and well, I think I hydrolocked my motor, and btw, I have a GSR swap done to my 95 civic. Well, I was wondering, would the motor mounts work on an LS motor? I can get one pretty cheap, so before I end up buying it, I was just trying to see if the mounts would work or if I would need to go ahead and buy new ones
Thanks
Thanks
Re: Question about motor mounts (albert)
huh? Why do you think you need a new mount? But yes it will work.
And why do you think you hydrolocked? Does your car start?
Re: Question about motor mounts (sol_dwn)
well i also might have shorted something out cause i try to start the car and it sparks from the battery and last night i was taking out the cd player so no one jacks me and it started burning around the switch to roll the windows down (white smoke came out)but when i try to start the car it makes a clunk noise from the motor but dont turn over
i would address the wiring prob first. it sounds like you have a hot going to ground some where try to look at all the wires on your car and see if any of them have melted insulation or any arc or burn marks on any part of the car. also look at all your fuses and relays, look for any burns or melted plastic. btw have you been getting shocked? hope this helps you out
as a matter of fact yes my wires under the hood are melted and it caused the taillight tostay on i have to disconnect the battery so it don't drain juice also the cluster stays on would i have to get the whole harness replaced?
i would buy a new wiring harness. you need to find out where the hot is going to ground before you put on the new harness. it maybe on the harness somewhere or somewhere else. just look for any exposed hot wires touching metal. hope this helps.
electrical problems like this really suck sorry man
thanks so much for the help!!!
another ? I could buy the harness from where the ceu plugs up to inside the engine bay right? Cause thats where the wires are melted
yes go to a salvage yard or mech shop in your area if you need the harness from the ecu to the engine you will have to get 2 wiring harnesses on for the engine and one from the ecu to the engine harness. try to find a U Pull It or something so that you can get exactly what you need. plus it will be a little cheaper
Hope this helps
Hope this helps
thanks again I guess i know what i'm doing this weekend my friends girl's parents own a salvage yard with alot of hondas so i'll be there but thanks again
travis
23
08-30-2004 09:08 AM
