suspension question ??
i was wondering how to adjust the ride height on koni yellow shocks/struts ..
i have a 00 si with eibach sportlines and koni yellows, and right now the ride height is too low .. i live in NY which has crazy potholes etc ..
i wanted to raise the height around 3/4 of an inch .. is that possible by adjusting the shocks ? and how much would it cost to do it professionally ?
or should i just reinstall the stock springs ?
pleaseeee helpppp, i cant drive this thing while its this low !!
Re: suspension question ?? (killaj12)
you should reinstall the stock springs and then get your self a good set of coil overs. the coil overs are what alow you to adjust the height of your ride.
You can't adjust the ride height via the shocks. You'll have to invest in different springs or perhaps some coilovers. Ground Control makes good affordable sleeve type coilovers.
