no crank no start tried everything help!!
ok so i have a 94 del sol and i cant get it to start or crank i checked everything. these are the things i did i changed the distributor battery starter checked my grounds and clutch switch. may b the main relay? please help
Re: no crank no start tried everything help!!
Sounds like the little rubber stopper that presses on the starter switch at the top of the clutch pedal has broken and fallen out.
1) Unplug the solenoid wire at the starter and have a buddy hold the key in ON(III)/Start while you measure voltage to body ground at the unplugged connector.
2) With the key off, measure voltage to body ground at the large wire for the starter motor.
Post the voltages.
Post the voltages.
What's the voltage across the two battery posts? Based on your voltage readings, one problem may be that your battery is dead.
I already took it to autozone and they tested it twice and it came out good. I also noyiced my fuse was popped for the hazard, I tried a 10a and it blows it right away, I then tried a 30a and it heated up, do you guys think a short with my lights or something similar would cause a no start? thanks.
s.langley
02-03-2019 06:31 AM
dirtygerman
06-17-2011 07:04 PM
