ex motor into lx need 02 sensor help
Im in the process of putting the complete d16y8 swap from a 98 civic ex into a 98 civic lx, im using everything from the ex (motor,trans harness,ecu)the lx was just a body when i got it. my question is the lx body does not have the o2 sensor plug under the car like the ex does,i know its part of the ex cabin harness. what is the best way be able to fix this problem? thanks guys
Re: ex motor into lx need 02 sensor help
The secondary O2 harness will be part of the under-hood harness for an LX/DX. You can either buy an extension harness (cheap), or peel off the shrouding and pull it out yourself.
Technical Hero
If your using the EX harness you'll have to wire in the 2nd 02 manually
http://ff-squad.com/wp/?p=395
http://www.ff-squad.com/technet/wiring.obd2a.htm
Technical Hero
Basically use wire taps to tap into those locations, there will already be wires there. Don't remove and pin at this locations as they may be shared ground and power locations with other sensors.
B96v6
12-16-2005 06:34 AM
