Need some input settin up my civic as a dd
I have been debugging/setting my 98 hx w 205,000mi up as a DD since I got it in june.
Things done
head rebuilt
solved water leak in trunk
valve adjustment
distributor cap
rotor
spark plugs
new radiator
oil change
fuel pressure regulator
swapped aic valve in from another car
removed lower air box (all cracked up)
new air filter
new harmonic balancer
flushed fuel filter (new one tomorrow)
general interior reassembly
I need a new lower drivers side motor mount and was thinking of using these
http://www.summitracing.com/parts/en...ic?prefilter=1
anyone have experience, i couldnt find a write up on these in faq section
I also need the sender on top of the manual transmission for speedometer.
Is there anything else pressing i should get done/troubleshoot ahead of time as winter is coming and I dont have a garage large enough to work on this in doors come cold season?
The car runs well, idles ok as long as air conditioner is turned off, belts look good and tires ok
Any input is appreciated, any brand recommendations are welcome
Thanks
Things done
head rebuilt
valve adjustment
distributor cap
rotor
spark plugs
new radiator
oil change
new air filter
Thanks
Re: Need some input settin up my civic as a dd
Chillax buddy. Not sure about the mounts, but a duralast VSS (speedometer sending unit you referred to) has a lifetime warranty and i have one in my car. Works great. Very easy to swap out.
ButtersNZ
Honda CR-V & Element
11-17-2015 09:38 AM
