EG Bseries T bracket issues
Hey whats up everyone kinda new to this site but have been lurking for a long time. So heres my issue I have a 95 EJ1 and I'm swapping in a B18b with a cable trans in it. I have all the mounts and everything motor is currently in the car right now. The only issue im having is the T bracket. I have a T bracket from a 95 GSR and also a T bracket from a DA. This swap was in my 90 si hatch but got pulled since car was crashed. The only issue im having is the GSR bracket is too long and doesnt have enough clearance and hits the rear mount.
My EF mount has enough clearance and is long enough but is too narrow and doesnt fit over the rear mount. Anybody got any input? Im leaning towards the 99-00 T bracket since its shorter but im wondering if its the same width where the rear mount bolts up. Anything would help out right now. This is my only car right now so i gotta get it up and going
Re: EG Bseries T bracket issues
are you still using the mount kit that you had in your EF?
if your using the mount kit for your model car than you may want to check out this cable conversion mount from hasport: http://hasport.com/store/index.php/m...-eg/egbcc.html. this should allow you to use the cable trans in your hydro car.
if your still using the EF mounts then go ahead and get this mount kit from hasport: http://hasport.com/store/index.php/m...s-eg/egb1.html. this should get your gsr t-bracket to line up and fit properly.
Thanks for all the input everybody. Im using EG mounts with the Innovative Hydro to cable cable conversion kit. The T bracket is from a manual Since it has the pocket to slide over the trans for the top bolt. I was able to get everything bolted up but had to drill new holes for the rear mount and elongate the hole for the top bolt on the T bracket/ tranny side. Now I´m having issues with the shift linkage being too long approximately 1 3/4 inches too long
corollagts33
12-07-2005 10:37 PM
jDmImagE
10-15-2005 01:18 PM
