2000 civic fuel pressure regulator help
Old 09-25-2013, 06:21 PM
Yajhershey's Avatar
Default 2000 civic fuel pressure regulator help
My 2000 civic b18c1 starting sputtering at stops a while back, I went and got a used fuel pressure regulator at the junk yard and switched it with the one I had on. It ran good for about 2-3 weeks with no problems what so ever and no sputtering idling around 1k. 2 days ago it started doing it again, even worse then before, like it's not getting enough gas, I'm thinking about buying a new one but want to know if I should just get a stock fuel pressure regulator or a different one, there are pricey and I want to get the best for my car.
Old 09-25-2013, 09:18 PM
crazyhouse2011's Avatar
Default Re: 2000 civic fuel pressure regulator help
Fuel pump, my friend. Look into the fuel pump as a potential cause.
Old 09-25-2013, 09:54 PM
Yajhershey's Avatar
Ok I will look into a new fuel pump, so do you think my regulator is not the problem then since I kinda changed it and the symptoms went away?
Old 09-25-2013, 09:55 PM
Former User's Avatar
Have you replaced the fuel filter and done an ignition system tune up?
CEL codes?
Old 09-26-2013, 12:03 AM
Yajhershey's Avatar
I changed my fuel liter last month before I changed my regulator. I changed spark plugs in June.thats about it, no cel as of right now, the last cel that came up was about 2 months ago for a knock sensor but I changed that already
Old 09-26-2013, 01:28 AM
Technical Hero
HondaPartsHero's Avatar
Not that they don't but I've never had a Honda regulator go bad. Have you checked your fuel pressure? What do your plugs look like?
Old 09-26-2013, 01:49 AM
Yajhershey's Avatar
I will check my spark plugs again to see if they look bad, and how do I check my fuel pressure to see if the gas flows evenly in my car I read somewhere about that on hondatech but I am not to sure on how or where to start on that
Old 09-26-2013, 04:23 AM
If the plug wires, cap, and rotor are old, replace them and go from there.
skUnK2jdm
01-30-2007 03:55 PM
iNetForce
11-13-2005 08:27 PM
ricecooker415
08-14-2005 08:00 AM
hybridtech
04-17-2005 03:44 PM
E Swift
11-04-2002 07:55 PM
Quick Reply: 2000 civic fuel pressure regulator help
