Del sol bogging
Old 09-30-2013, 06:44 PM
jdmeg6honda's Avatar
Default Del sol bogging
I have a 93 del sol with a d16z6 swap rebuilt with 15xxx miles
New catalytic converter
New 02 sensor
New spark plug
Spark plug wire
Cap and rotor
I just passed smog
My problem is my car Boggs random while I drive
No check engine code
I got the car bone stock d15b7 and it Boggs also
so I swap a d16z6 and replaced a lot of stuff
I can't figure why the car Boggs
The d16z6 was in my other car and ran with no problem before I did the swap
Old 09-30-2013, 07:48 PM
Eteggy's Avatar
Default Re: Del sol bogging
Same issue with my girls car also while idling can't figure it out
Old 09-30-2013, 08:08 PM
erikgillette87's Avatar
Plugged fuel filter?
Old 09-30-2013, 08:59 PM
No I got new fuel filter
And my injector are clean it sprays fine
Old 09-30-2013, 09:43 PM
crazyhouse2011's Avatar
Check the TPS and possibly the fuel pump or the fuel pump relay
Old 09-30-2013, 10:13 PM
My tps is fine I had this whole swap in my other car and it ran perfect I did the swap because i was thinking it would help
And change my main relay with 3 different working relay
How do I test my fuel pump?
Old 09-30-2013, 10:26 PM
jbpnoman's Avatar
Don't just say "it's fine", test and re-calibrate it.
Old 10-01-2013, 03:55 AM
delsolintegra's Avatar
check the fuel pump sediment screen
Old 10-01-2013, 04:25 AM
Eteggy's Avatar
Could it b a clogged catalytic converter?
Old 10-01-2013, 06:33 AM
A clogged cat is a possibility.
Old 10-01-2013, 08:33 AM
Nope i even went staight pipe same issue this is my second cat on car so far
Im running out of ideas
Old 10-01-2013, 07:57 PM
grdy98's Avatar
check fuel pressure regulator?
Old 10-02-2013, 04:48 PM
How do i test the fuel pressuee regulator on this motor? I found a link for b16 but not sure if its the same
digital sol
08-30-2018 07:56 AM
digital sol
03-19-2018 08:00 PM
86aw11
12-24-2015 08:18 AM
B17SolRide
18
05-12-2012 06:34 AM
Ninebr8kr
14
03-20-2012 08:09 AM
Quick Reply: Del sol bogging
