Clutch Master Cylinder Reservoir Hose
Does anyone know where to get that rubber hose to connects from the Clutch reservoir to the Clutch master cylinder? My clutch is very spongy even after I bought a new slave cylinder and master cylinder. I bled the system but I still have a spongy clutch pedal. I noticed that there was a little bit of brake fluid coming off from one of the clamps. The clamp looked like it was on there tight so i'm not sure if the hose is the problem. Not sure what the hose was called so I googled "clutch master cylinder reservoir hose" on google, amazon, and even autozone and didn't get the correct part. Any info will be appreciated.
Re: Clutch Master Cylinder Reservoir Hose
^hold on there, if it's the flexible hose that runs from the MC to the hardline you can't just use a regular VAC hose and in this case that's the only hose I can think of that OP is talking about.
OP post pic of hose>
You are Correct! It's The Flexible Rubber Hose (Black one). I'll Try To Post Up A Pic
chris89
Transmission & Drivetrain
11-14-2014 06:53 PM
