Distributor, which component controls RPM signal
Does anyone know which component in the distributor is responsible for sending the rpm info? Here is a thread with tear down pictures for reference.
http://civic-eg.com/viewtopic.php?p=223990
I got a new one as my old one was toast (distributor). The new/used one that I received has a good shaft, however my tach does not work now.
My vehicle is a 92 vx with the d15z1 engine and I'm using the stock distributor (TD-42U).
I was thinking that I could simply swap the electronics from one to the other, however if I didn't have to completely tear the entire thing apart then that would be great.
Re: Distributor, which component controls RPM signal
I know the wiring is good. It worked great with the last distributor. I'll have to take a look at them and see which component is "tied" to the blue wire in the Dist. and then swap that component.
That's simply a waste of time to take the gauge cluster out to test the wire between there and the distributor plug when it literally sat there between installs for 2 days and it worked perfectly with the old dist. The only variable in the equation is the new distributor.
Thank you very much for the help! Both of you. I will likely get those swapped this evening and I'll post up my findings.
