A/C questions
A/C questions
Whats up guys , i would like to install a/c in my car but since im running a integra full size radiator i can no longer use the oem condensernor the oem lines so i have a few questions.
would it be possible to use a integra condenser since it sits towards the front of the radiator?
can i get custom lines done but instead of the hardline can the be rubber so i can run them where they wont be seen?
Re: A/C questions
Possible if you can get custom line when it's no problem.
I have seen someone tak ethe fitting and weld adapters to it for custom lines.
Re: A/C questions
I was thinking of getting hydraulic hoses made to the length that i need them to be so i can get rid of all the hard line , or does the ac system needs to have aluminum piping for some reason?
Re: A/C questions
as said i remember someone doing it for a civic. they had a shop make the lines so they could tuck the condenser.
I wish i had all the information because i want o run a full size condenser to help the ac better cool in my ac turbo setup.
