Help s4PA+P2Y
Re: Help s4PA+P2Y
Model - CIVIC
Year - 2000
Body type - 3 door
Engine Code - D15Z6
Transmissions - 4AT s4pa
modification - 1.5I
Region code - KG Germany
Options - SRS DRIVER & PASSENGER; LEFT-HAND DRIVE; POWER STEERING;
Year - 2000
Body type - 3 door
Engine Code - D15Z6
modification - 1.5I
Re: Help s4PA+P2Y
no solenoid A B
Re: Help s4PA+P2Y
Use a voltmeter to test for continuity between one wire from the solenoid, to each of the pins on the ECU plugs. When you find the wire with continuity, there's your wire. Repeat with the second wire.
