EK Hasport mount problem
Left Hasport mount doesn't sit flush with timing side bracket
Holes are too small, is this a fault?
EK STK b-series
EK STK b-series
Re: EK Hasport mount problem
Yep it's the Si bracket
It shouldn't matter anyway, these are Hasport stock replacement so suppose to fit D and B series
I checked the D series bracket and it doesn't fit that either. Same problem
I even triple checked on an ek9 bracket I have here, all the same
Definitely Hasport issue
I trust you have jacked up the engine ? considering when you remove a mount it's going to sag a bit, I had to fiddle with the engine a bit installing my 94A ones on my dc2 it should fit. get a jack+board under the oil pan and mess around with it a bit
There are 2 types.
3 bolt post mount commonly found on B18C and 2 bolt post mount found on B16A
I've emailed Hasport, hopefully sorting out something soon
