Coolant leak under the hood?
MY 2000 Civic leaks coolant quite excessively. I just don't know where, even though I know the spot. A small coolant well right on top of the right side radiator fan. I checked the hoses around, but didn't spot any tears or leaking points. The left side ac radiator fan has no coolant. The splash shield has coolant. I have to refill the reservoir after several times of short trips.
The cap is fairly new, and was checked out okay. The air box has signs of coolant splashed onto it. The direction is to the rear side - longer drips closer to the driver side.
I'm planning to go to pep boys to ask them.
What do you think this is? I will upload pictures if it's way better.
Re: Coolant leak under the hood?
Could be a crack in the radiator or pinhole in a hose that only squirts when the system develops enough heat/pressure. Hoses are cheap. So are radiators. Engines are expensive. Get this fixed ASAP.
PHANTOM MENACE
Let it run and watch for the leak while it's hot and running. A friend of mine had a similar issue that you could only see after the car was at operational temperature. It was a super small pin hole leak on a hose that only leaked when enough pressure was built up in the system.
one more following QUESTION!
First, Thanks to you guys, through pressure test, found there's a crack on the top side of the radiator.
(I have the picture on my computer but it doesn't let me, other than a link) So, here's a similar one.
The crack's right under the radiator cap, where the silver aluminum part and the plastic part joins. The coolant sips through the gap. One more, right under the cap in the midway between the aluminum part and the cap, so, on the plastic part, there's one more crack.
I was wondering if there could be any long-lasting cure for this. I was going to order a new radiator, but wanted to make sure if I could save it.
Both the cracks are about two inches long. Both are on the inner side of the radiator.
Got it. During the pressure test, the gauge didn't go past 10, it dropped to zero in seconds - as you would know, the cap says it holds max 16 lb.
Would I be able to drive like this for a week (could be as fast as four days) - I think I 've been driving like this for more a bit than a week -, until I get the product from online and install it. I'm going to keep refilling the coolant.
As long a you are VERY careful to keep your coolant full and topped off, you could probably get away with it. Remember, though, as soon as your temp needle starts moving past where it belongs, you're risking doing serious motor damage.
Get a Koyo Radiator and install the OEM fan on it.
When you get the Koyo and compare it side-by-side with the original, you will see the OEM radiator was obviously doing nothing and you were probably better off with a radiator delete (ie. lower and upper hose looped together). This would have been more effective than that so-called OEM radiator (which is rubbish).
An all aluminum radiator is definitely the best, but a legit aluminum radiator and not an eBay part.
Not sure if serious:/
The OEM rad in that pic also had the AT cooler (pre-swap) so the capacity is probably further diminished.
Nonsense radiator.
Nonsense radiator.
ShadowDaisy82
11
08-07-2015 10:34 PM
soulo
06-08-2008 10:28 AM
