where to buy a crank bolt?
Hey guys, so I just bought a 1997 civic lx 1.6 from a guy at work. It has 230k miles but he has no idea when the timing belt was changed last. Being that its an interference engine, and having no idea sounds entirely insane to me, I wanted to change the timing belt today.
My issue is that the only place I know that sells a crank bolt for the crank pulley is a Honda dealership. Do any of you guys know any other parts stores I might be able to find one on a sunday? I know some people have used loctite red or blue on reused bolts, but even so, the threads are one time use only so I don't think that's a good idea.
Re: where to buy a crank bolt?
ARP sells a replacement bolt, and a number of companies carry ARP, but you'll probably have to wait for shipping. If you absolutely want it today, it's time for you to start driving around and see if anyone can help you.
thanks jbpnoman.. I will have to drive around I guess.. I'm starting to wonder if mechanic shops have a stock of crank bolts for every make just lying around or if they are all just using loctite on old bolts every time.
Seagull Management
No one ever replaces crank bolts in the real world unless you're at a dealership (even then most of the time the old bolt gets reused) I don't even put Loctite on them.
I've always reused the bolt, no Loctite. The manual doesn't say to replace the bolt. It just says to apply engine oil to the threads.
I went ahead and bought another bolt the other day since I found out I have a week off work. It was actually 10 dollars at the dealership.
I couldn't believe how loose the timing belt was before I changed it. I'm assuming the last guy didn't know what he was doing because there was no play in the tensioner bearing and it was bolted tighter than the torque spec the manual says it should be.
Seagull Management
It will be fairly loose in certain places.
There's not supposed to be any play in the bearing.
Other than rod and head bolts no one torques anything in the real world. The biggest thing with the tensioner bolt is that it's tight, you don't want the tensioner to move. If it's a bit tighter than the torque spec it wont matter unless it's so tight you strip the hole or break the bolt.
I'm all for saving time when I'm working on a car, but to me it doesn't make sense not to torque bolts and nuts correctly if i have a torque wrench beside me and the torque specs are staring me right in the face on a diagram. The only time I don't torque bolts to spec is if its pretty impossible to get that size ratchet in there.
Seagull Management
You can't make any money on flat rate with a torque wrench. A job only pays book time so if it takes you longer you're working for nothing after the allotted time, if you finish in less time, bonus. The faster you work, the more money you make.
You do make a good point. I would probably do the same thing if I worked in a garage. In my situation in my driveway its a good thing I have time to do it I guess. I know if it paid more I would work as a mechanic but I'm too much of a perfectionist for it to be worthwhile for me haha
however driveway/home garage is a different story. i'll torque any internal engine component(so anything that's under the valve cover) and some suspension/brake components. but if I were at a shop no drought you'd be loosing out buy torqueing things like wheel studs and things along that nature.
Above stated truths and reasons are exactly why I never let anyone work on my car short of a machine shop and always re-torque my wheel lugs the minute I get home after tire work. I also torque everything to spec that I can fit a torque wrench on. Never had anything strip, break or come loose.
Last time I re-torqued my lugs the shop had them so tight I almost couldn't break them loose. I'd have been pissed if this happened on the roadway.
My apologies for understating the crank bolt cost. Curse my feeble aging brain.
You won't make money with stripped/broken parts or parts falling off the cars. I guess that's where the grunt wrench comes into play (torque to 3 grunts). Sadly what you say is true. Cleanliness is also sacrificed in most shops.
Seagull Management
Fwiw, when I worked at Honda we had some preset torque wrenches, one for oil filters, one for drain plugs and two for wheels. The way we used wheel torque wrenches was to crank the lugs nuts on with the impact gun and then check to make sure they were all at at least 80 - 90ft lbs. Usually one per wheel ended up being less. Don't let anyone try to convince you over-torquing wheel nuts leads to warped rotors, it doesn't.
Hate to break it to ya, but torque sticks are good for only one thing - breaking customer's ****. I've never seen a reputable dealership or speed shop use one. Only "tire shops" and quickie lube places use them.
Seagull Management
Torque sticks are torque limiting, that's about it. You never really have any idea what you have for torque, especially on alloy wheels. The only way they're any good is to use a torque stick and then run around behind with a torque wrench.
Pretty sure I'm preaching to the choir here, though
The Credible Hulk
Yes I would. You're sandwiching an 1/8th to 1/4 inch piece of metal between the wheel and a solid hub, it just can't warp that way.
The Matco ones I have are supposedly +/- 4%.
Either way I'll take that over the random guess method EVERYTIME!
As for reputable dealerships not using them I got mine when my wife went from being a tech at Heritage Subaru/VW (one of the biggest Subaru VW dealerships by volume on the East Coast) to being a parts tech. Their techs use Matco exclusively and they ALL use em.
I like the tuna here
I'll jump in with my $.02 worth...I've done a timing belt job on a honda probably around 15-20 times, I've never used loctite or replaced the bolt. I did have the pulley come off ONCE on my CRX, but I strongly suspect that I actually just forgot to tighten the pulley that time, lol.
When I'm working on my own car at home or a friend or family member's car, I always torque bolts to spec... but I'm very thorough and picky about my Civic. If I were in a shop, on book time, I'd probably just torque until it felt right.
I will say that any bolts that need tightened in a sequence (head bolts, oil pan bolts, manifold bolts, etc.) should ALWAYS be torqued to spec. If you torque those out of sequence and unevenly, it's just asking for trouble (and by trouble, i mean leaks).
As for the crank pulley bolt, I've never replaced mine and it's on 311,000 miles. The FSM makes no mention of replacing it either. I think you just wasted $10 bucks. :/
