Oil dipstick tube removal. Please help!
Old 09-22-2013, 04:39 PM
mlab's Avatar
Default Oil dipstick tube removal. Please help!
Hi,
Replacing the timing belt on my 2000 Civic DX (D16Y7). You'd think the toughest part would be the crank pulley...no, that was easy. Way harder is removing the stupid oil dipstick tube. This is only to get to one last bolt holding the lower timing belt cover. 2 options here : Use some magical tool that can get to the bolt in a ridiculously tight space or remove the tube.
I tried pulling on it, rotating it with pliers, hitting under the bottom flange with a really small screwdriver. Nothing works and I don't want to get mad with it and break something. I don't get why I can't find any tip about this in the manual, or in the 100's of timing belt write-ups, or vids on youtube. Does everyone else just yank it out with one hand?
Thanks
Old 09-22-2013, 04:47 PM
Marvin1985's Avatar
Default Re: Oil dipstick tube removal. Please help!
There's a clip on it you pop off about mid tube then just grab it and pull up and back. Yes everyone else just uses 1 hand lol
Old 09-22-2013, 04:58 PM
mlab's Avatar
Sorry, forgot to mention, I popped that clip off already.
Old 09-22-2013, 05:00 PM
Long Grain Wild's Avatar
It should just pull up and out. The only thing holding it in at the bottom is the now petrified O-ring where the tube goes into the hole at the bottom.
Give it a twist and a yank.
Old 09-23-2013, 12:28 PM
strategy400's Avatar
Put some vise grips on it and turn back and forth while you pull.
Old 09-23-2013, 03:41 PM
I like the tuna here
DumpdEJ6's Avatar
There is actually a small bolt down at the bottom of the dipstick tube, holding it in place. Once that it loosened, the dipstick tube will slide right out. Hopefully OP didn't follow the rest of the advice here, SMH.
Old 09-23-2013, 07:53 PM
I think we were going on the assumption that OP had removed all related fasteners and was still having trouble extracting the tube.
Old 09-23-2013, 08:53 PM
GDD Member
slomofo's Avatar
Seeing how the thread has gone so far, I'll assume the power steering pump is still in place. Unbolt the pump, detach the power steering reservoir from it's bracket, and move it over to the side. That'll give you more wiggle room for your hands and the tube.
Old 05-18-2014, 01:38 PM
mlab's Avatar
Months later...!! I just realised I'm not getting email notifications of anyone's replies. Thanks everyone. No bolt involved actually (Y7). Just to help anyone with the same problem in the future : some tubes are a bitch… I used a thin kitesurfing line, tied a loop under the flange at the end of the tube, tied the other end to block of wood and used both hands to yank it out.
goriverman
11-03-2010 05:07 PM
saikouEF8
11-13-2008 10:28 PM
VTgringo
08-11-2004 03:47 PM
slipperyduck
06-11-2004 10:07 PM
integRated109
10-14-2002 11:38 AM
Quick Reply: Oil dipstick tube removal. Please help!
