need help about RPM.
I need your help Friends..I've just swapped a JDM B16A1 engine (p30 Ecu)in my ek.Everything was going smoothly when suddenly i heard a strange loud sound coming from my distrbutor and check engine light on.I changed the bearing in the distributor.Now the RPM cannot go beyond 3500 and i cannot even use data logging to read the CEL error which i was able to do before these problems arise.What can cause these 2 problems?
Re: need help about RPM.
thought they're just gears...
either way your in limp mode. if you can't get your cel's you have crap wiring somewhere else. but get your cel's then fix em. and you should get out of limp mode and return to normal.
