code 54 crank fluctuation sensor?
bought this car couple weeks ago runs really good, head gasket does leak a little oil but its all good with me for now
anyways D16Y7 and I started notcing that the check engine light was never on when you turn the key to on
I asked the guy when I bought it if it had an y CEL's
well I took the dash apart to find the ****er removed the bulb!
sure enough I replaced it and the light was on!
so I did the cel check and its code 54 crank flucutation sensor
what should be my course of action?
Re: code 54 crank fluctuation sensor?
Do a visual. Alot of times the sensor subharness isnt pushed back into its slot and the alternator belt rubs and damages the harness.
ok so it most def will have to be looked ta from the underside then , cause from the top looking down its too tight to see or feel anything
form51
13
03-16-2020 02:52 PM
pityocamptes
12
12-14-2011 09:48 AM
underb00steg6
04-01-2009 11:13 AM
markovwgti
07-24-2008 11:08 AM
2000, 54, alternator, apart, civic, code, connection, crank, crankshaft, fluctation, fluctuation, harness, honda, location, sensor, tech
