400hp goal, use high or low impedance injectors???HELP!
I have a 96 civic. Obd2 wire harness with a d16z6 engine. got a obd1-obd2a ecu conversion harness. I was wondering what injectors i should use. Either high or low impedance? Do i need a resistor box? cause i heard the older civics( 1990-1995) have resistor boxes and the (1996-2000) dont have them? help!! or if i get high impedance injectors do i need to wire in a resistor box?
tuning on hondata s300
this is my build-
d16z6
Engine-
Vitara pistons- 8:5:1 compression
Eagle h Beam rods (tuner toyz)
Block guard
Ported oil pump
Head-
Bisimoto stage 3 camshaft
Supertech Valve springs and retainers
Ported and polished
5 angle valve job
Skunk 2 intake manifold
B series throttle body
Drivetrain-
S40 TRANS
XTD STAGE 3 CLUTCH
5 speed
this is my build-
d16z6
Engine-
Block guard
Ported oil pump
Head-
Ported and polished
5 angle valve job
Drivetrain-
S40 TRANS
XTD STAGE 3 CLUTCH
5 speed
The Grumpiest
Re: 400hp goal, use high or low impedance injectors???HELP!
Do a search next time.
https://honda-tech.com/forums/forced-induction-16/fuel-injectors-400whp-2886393/
nastyARE
12-31-2009 02:45 PM
jdmdikk
05-08-2009 06:50 PM
B18C5civic
10-23-2005 09:26 AM
