Overhauling my D13B soon.. Which service manual should I use?
Hi HT members,
I'm about to do a major overhaul on my JDM EK2 Auto D13B engine, but I dont know which service manual should I use. Those I found on web is for D15z1/D16Z6 EG Service Manual and D16y7/D16Y5/D16Y8 EK Service Manual. I know D16Y7 don't have VTEC system same as mine, but iam concerning about the bolts torque specs and different sizes on the internal parts. PLEASE HELP
TQ.
TQ.
The Grumpiest
Re: Overhauling my D13B soon.. Which service manual should I use?
Yes there are D13s.
D13 Series Engines (1.3 Litre)
D13B1
* Found in:
o 1988-1991 Honda Civic EC (European Market)
+ Displacement : 1,343 cc (82.0 cu in)
+ Bore and Stroke : 75.0 × 76.0 mm (2.95 × 2.99 in)
+ Compression : 9.5:1
+ Power : 75 hp (55.0 kW, 76.0 ps) @ 6300 rpm
+ Torque\
+ Valvetrain : SOHC (4 valves per cylinder)
+ Fuel Control : Single Carburetor
D13B2
* Found in:
o 1992-1995 Honda Civic DX (European Market)
+ Compression : 9:1
+ Power : 74.9 hp (55.9 kW, 76.0 ps) @ 6300 rpm
+ Torque : 75.2 ft·lbf (10.4 kg/m, 102 Nm) @ 3100 rpm
+ Cam Gear : 37 tooth
+ Piston Code : PM1G
+ Head Code : PM3
D13B4
* Found in:
o 1996-2002 Honda Civic LXi/EXi/DX
+ Compression : 9.75:1
+ Power : 95 hp (70.8 kW, 96.3 ps) @ 6500 rpm
+ Torque : 94 ft·lbf (12.8 kg/m, 127 Nm) @ 4200 rpm
+ Valvetrain : SOHC (4 valves per cylinder) - 16 valve
+ Fuel Control : Multi-point fuel Injection, PGM-FI
D13B7
* Found in:
o 1998-2001 Honda Logo 3D/5D
+ Bore and Stroke : 75.0 x 76.0 mm
+ Compression : 9.2
+ Power : 65 hp (48.54 kW, 66 ps) @ 5000 rpm
+ Torque : ? ft·lbf (11.3 kg/m, 110.82 Nm) @ 2500 rpm
+ Valvetrain : SOHC (2 valves per cylinder)
D13C
* Found in:
o 1989-1994 Honda City CE, CE Fit, CE Select, CG, CR-i, CR-i limited, CZ-i, New Fit (Japanese Market)
+ Displacement : 1296cc
+ Bore and Stroke : 73.7mm x 76mm
+ Compression : 9.6:1
+ Power : 98 hp (73.55 kW, 100 ps) @ 6500 rpm
+ Torque : 84 ft·lbf (11.6 kg/m, 113.76 Nm) @ 5500 rpm
D13B1
* Found in:
+ Torque\
D13B2
* Found in:
+ Compression : 9:1
+ Head Code : PM3
D13B4
* Found in:
D13B7
* Found in:
+ Compression : 9.2
D13C
* Found in:
I think he is looking for one for his engine and can't find one. He can only find ones for the other d's.
Sorry can't help you on it though.
I study the service manual for D15/D16, both has different torques spec for different parts. I don wan to use that torque, I scare it will damaged my parts bcause of over tighten.... Or is it okay if i use the one closses to my engine capacity which is D15?
Anyone...... need this urgently..
Nocturnal
01-17-2003 09:14 PM
Nocturnal
15
01-06-2003 09:23 PM
