My 2000 si manual problem
Alright, i own a 2000 civic si, black, and i had my brother driving it to work, because he didnt have a car at the time, he made the short shifter loose, and now i have replaced the short shifter, the shifter was grinded off at the bottom where u connect it to the rod going to the tranny, and i put a brand new one in, it makes a grinding noise when ur in a low medium rpm , say as if i was going 70 on the highway, and the petal was half way down just crusing on 70 it would make this grinding noise , untill i gave it gas..... any ideas?
Re: My 2000 si manual problem
no nothing with the clutch lol, the clutch is a stage 2 skunk 2 clutch, its already in gear, say its in 5th, im riding down going 70... and my shifter will just rattle, like a grinding noise, i dont know what it can be. , and yes i push the clutch to the floor ever time i shift.
Shift linkage hitting the exhuast? Are you sure it is coming from the shifter?
I have never heard of someone making the shifter "loose" by just driving.
I gotta tighten it down more, and yes my exhaust is 3 inch, from the headers down .... and the outlet is 5 inch.
ebay exhaust probably, but yes your shifter can bang against your exhaust if either is not installed correctly. Look under your car and look at the the bolts holding your shift linkage to the bottom of your car. One or both of the bolts are probably loose which is causing it to feel loose. It is also probably hanging lower as well and it is probably vibrating against your exhaust. Very simple. Just go look at it.
If your car is not turbo, why in the world do you have a 3in exhaust on there? Your loosing lots of power.
actually its not so bad, the power is pertty good, and it will be boosted soon thats why i got the exhuast now, and my old one was pertty much gone.
efinit
12-30-2004 08:11 AM
